Yes Tectu I do have other code as I was only using the example code as a guide.
I have worked out that I can use GWIN and i am starting to redesign with it.
Just one thing, I cannot access the Doxygen pages on your site to get more info as I am tying to work with gwinDrawString is there a alternative location for the documentation?
little help with ADS7843
Re: little help with ADS7843
Just found it..
The link on the bottom of your GWIN Window page is,
http://chibios-gfx.com/doxygen/group___g_w_i_n.html
The address that worked is,
http://chibios-gfx.com/doxygen_master/g ... w_i_n.html
Thanks Google
I have had a look at it but how do I set the font so i can use gwinDrawString?
Thanks Google
Thank you very much for finding the dead link. I have replaced it with a link to the general doxygen page since we offer both - the latest stable and latest master doxygen build.
I am not sure if I understand your question about the font. The button docs show an example how to open a font and use it afterwards. It also describes that you have to enable the font in your gfxconf.h.
There some more demo code showing how to deal with fonts.
I have progressed a bit further I have set the font but when i try to draw string, Only the first letter of the string will appear.
I am using this,
And it outputs only - D
I am using this,
font = gdispOpenFont("Larger");
GW1 = gwinCreateWindow(NULL, 20, 10, 150, 460);
gwinSetColor(GW1, Black);
gwinSetBgColor(GW1, White);
gwinSetFont(GW1,font);
gwinClear(GW1);
gwinDrawString(GW1, 20, 150, "Dawe");
It looks like the rest of your string would be drawn outside of the window. You can check that by disabling the clipping in your gfxconf.h. Please do this just for testing. Make sure you enable it afterwards again.
The clipper doesn't draw anything that gets drawn outside of the corresponding widget are.
Ok,
I have disabled CLIP and the problem still persists, The "D" is drawn in the top left of the window so it should not be to large for the window area.
My full code is as follows,
Also I have discovered that when I use the DrawString the code stops.
The buttons do not work and the output that I toggle also stops, But without the DrawString everything works..
#include "ch.h"
#include "gfx.h"
#include "chprintf.h"
static GButtonObject gClear;
static GButtonObject gSet;
static GListener gl;
GHandle GW1, GW2;
static WORKING_AREA(SampleWA, 128);
* LED flashing thread.
static msg_t SampleThread(void *arg) {
//Set Pad Mode's
palSetPadMode(GPIOC,15,PAL_MODE_OUTPUT_PUSHPULL);
font_t font;
GW2 = gwinCreateWindow(NULL, 200, 100, 400, 370);
gwinSetColor(GW2, White);
gwinSetBgColor(GW2, Blue);
gwinClear(GW1);
gwinClear(GW2);
gwinFillCircle(GW1, 20, 200, 15);
gwinDrawString(GW1, 1, 1, "Dawe");
while (TRUE) {
palSetPad(GPIOC,15);
chThdSleepMilliseconds(500);
palClearPad(GPIOC,15);
int main(void) {
GSourceHandle gs, gsClear, gsSet;
GEvent *pe;
GEventMouse *pem;
GEventGWinButton *peb;
coord_t swidth, sheight;
GHandle ghc, ghClear, ghSet;
font_t font;
/* initialize the hardware and the OS */
/* initialize the LCD */
gdispInit();
gdispClear(Black);
/* Get the display dimensions */
swidth = gdispGetWidth();
sheight = gdispGetHeight();
ghClear = ghSet = 0;
/* choose our font */
font = gdispOpenFont("Larger Double");
/* Initialize the mouse */
geventListenerInit(&gl);
gs = ginputGetMouse(0);
gdispClear(Black);
/* create the "clear" button */
ghClear = gwinCreateButton(&gClear, 660, 50, 100, 50, font, GBTN_NORMAL);
gwinSetButtonText(ghClear, "Clear", FALSE);
gsClear = gwinGetButtonSource(ghClear);
geventAttachSource(&gl, gsClear, 0);
gwinAttachButtonMouse(ghClear, 0);
/* create the "set" button */
ghSet = gwinCreateButton(&gSet, 660, 101, 100, 50, font, GBTN_NORMAL);
gwinSetButtonText(ghSet, "Set", FALSE);
gsSet = gwinGetButtonSource(ghSet);
geventAttachSource(&gl, gsSet, 0);
gwinAttachButtonMouse(ghSet, 0);
/* draw the buttons */
gwinButtonDraw(ghClear);
gwinButtonDraw(ghSet);
(void)chThdCreateStatic(SampleWA, sizeof(SampleWA),
NORMALPRIO, SampleThread, NULL);
while(TRUE) {
pe = geventEventWait(&gl, TIME_INFINITE);
/* button pressed... */
if (pe->type == GEVENT_GWIN_BUTTON) {
peb = (GEventGWinButton *)pe;
if (peb->button == ghSet)
palSetPad(GPIOD, 12);
else if (peb->button == ghClear)
palClearPad(GPIOD, 12);
return 0;
Ok the thread continues now the working area was not large enough and also the string is working..
Thanks
Thanks
Yeah, a too small stack size is the next issue. It can allocate enough memory to draw the D but not for the rest. Is now everything working? I guess you could fix your touchscreen as well?
Yes the touch screen is working your advice on the PAL mode's was the trick.
Things are all working now
Is there a way to make gwinFillArea color the same as the background not the foreground color so I can display as sample every second
I have got it to work like this,
gwinSetColor(GW1, White);
gwinFillArea(GW1,1, 30, 150, 10);
It would be nice to be able to dictate the fill color as in gdisp.
Hay Techu,
How do i change the main thread stack size i cannot find any info..
