Unable to get ILI9320 display driver working on STM32F
uweng14
Postby uweng14 » Fri Jul 19, 2013 3:13 am
I am trying to connect the HY28A LCD module, which uses the ILI9320 display driver, to the STM32F discovery board.
However, I cannot get the LCD to draw anything.
I have verified that the SPI pins are sending signals by probing them.
My main.cs and board file are posted below.
Any advice on how to get the display running is appreciated.
main.c
#include "ch.h"
#include "gfx.h"
 * Application entry point.
int main(void) {
   * System initializations.
   *   RTOS is active.
 coord_t      width, height;
   coord_t      i, j;
    /* Initialize and clear the display */
    gfxInit();
     sdStart(&SD2, NULL);
     palSetPadMode(GPIOA, 2, PAL_MODE_ALTERNATE(7));
     palSetPadMode(GPIOA, 3, PAL_MODE_ALTERNATE(7));
    // Get the screen size
    width = gdispGetWidth();
    height = gdispGetHeight();
    // Code Here
    gdispDrawBox(10, 10, width/2, height/2, Yellow);
    gdispFillArea(width/2, height/2, width/2-10, height/2-10, Blue);
    gdispDrawLine(5, 30, width-50, height-40, Red);
    for(i = 5, j = 0; i < width && j < height; i += 7, j += i/20)
       gdispDrawPixel (i, j, Blue);
    while(TRUE) {
       gfxSleepMilliseconds(1000);
gdisp_lld_board.h
 * @file    drivers/gdisp/ILI9320/gdisp_lld_board_example.h
 * @brief   GDISP Graphic Driver subsystem board interface for the ILI9320 display.
 * @addtogroup GDISP
#ifndef GDISP_LLD_BOARD_H
#define GDISP_LLD_BOARD_H
#define SET_RST      palSetPad(GPIOB, 8);
#define CLR_RST      palClearPad(GPIOB, 8);
   // Peripherial Clock 42MHz SPI2 SPI3
// Peripherial Clock 84MHz SPI1                                SPI1        SPI2/3
//#define SPI_BaudRatePrescaler_2         ((uint16_t)0x0000) //  42 MHz      21 MHZ
//#define SPI_BaudRatePrescaler_4         ((uint16_t)0x0008) //  21 MHz      10.5 MHz
//#define SPI_BaudRatePrescaler_8         ((uint16_t)0x0010) //  10.5 MHz    5.25 MHz
//#define SPI_BaudRatePrescaler_16        ((uint16_t)0x0018) //  5.25 MHz    2.626 MHz
//#define SPI_BaudRatePrescaler_32        ((uint16_t)0x0020) //  2.626 MHz   1.3125 MHz
//#define SPI_BaudRatePrescaler_64        ((uint16_t)0x0028) //  1.3125 MHz  656.25 KHz
//#define SPI_BaudRatePrescaler_128       ((uint16_t)0x0030) //  656.25 KHz  328.125 KHz
//#define SPI_BaudRatePrescaler_256       ((uint16_t)0x0038) //  328.125 KHz 164.06 KHz
 * 10.5MHz, CPHA=1, CPOL=0, MSb first, 16 - bits
static const SPIConfig spi2cfg1 = {
  NULL,
  /* HW dependent part.*/
  GPIOB,
  12,
  SPI_CR1_DFF | SPI_CR1_CPHA | SPI_CR1_BR_0
static inline void gdisp_lld_init_board(void) {
  palSetPadMode(GPIOB, 13, PAL_MODE_ALTERNATE(5) |
                           PAL_STM32_OSPEED_HIGHEST);       /* New SCK.     */
  palSetPadMode(GPIOB, 14, PAL_MODE_ALTERNATE(5) |
                           PAL_STM32_OSPEED_HIGHEST);       /* New MISO.    */
  palSetPadMode(GPIOB, 15, PAL_MODE_ALTERNATE(5) |
                           PAL_STM32_OSPEED_HIGHEST);       /* New MOSI.    */
  palSetPadMode(GPIOB, 12, PAL_MODE_OUTPUT_PUSHPULL |
                           PAL_STM32_OSPEED_HIGHEST);       /* New CS.      */
  palSetPad(GPIOB, 12);
  spiStart(&SPID2, &spi2cfg1);
static inline void gdisp_lld_reset_pin(bool_t state) {
   if (state) {
   } else {
static inline void acquire_bus(void) {
    spiAcquireBus(&SPID2);
static inline void release_bus(void) {
   spiReleaseBus(&SPID2);
static inline void gdisp_lld_write_index(uint16_t data) {
    palClearPad(GPIOB, 12);
    static uint16_t txbuf[1] = {0};
    //txbuf[0] = 0x70 | 0x00 | 0x00;
    txbuf[0] = data;
    //txbuf[0] = data >> 8;
    //txbuf[1] = data & 0xFF;
    while((SPI2->SR & SPI_SR_TXE) == 0);
    spiSend(&SPID2, 1, txbuf);
    while(((SPI2->SR & SPI_SR_TXE) == 0) || ((SPI2->SR & SPI_SR_BSY) != 0));
static inline void gdisp_lld_write_data(uint16_t data) {
    static uint8_t txbuf[2] = {0};
    //txbuf[0] = data;
    //txbuf[0] = 0x70 | 0x00 | 0x02;
    txbuf[0] = (data >> 8);
    txbuf[1] = (data & 0xFF);
    spiSend(&SPID2, 2, txbuf);
static inline uint16_t gdisp_lld_read_data(void) {
        //while((SPI2->SR & SPI_SR_TXE) == 0);
        //static uint8_t txbuf[1] = {0};
        //txbuf[0] = 0x70 | 0x01 | 0x02;
        //spiSend(&SPID2, 1, txbuf);
        static uint8_t rxbuf[2] = {0};
        spiReceive(&SPID2, 2, rxbuf);
        static uint16_t value = 0;
        value = rxbuf[0] << 8 | rxbuf[1];
        //test_println((char*)value);
        return value;
/* if not available, just ignore the argument and return */
static inline uint16_t gdisp_lld_backlight(uint8_t percentage) {
   //pwmEnableChannel(&PWMD4, 1, percentage);
#endif /* GDISP_LLD_BOARD_H */
Thanks,
David
Re: Unable to get ILI9320 display driver working on STM32F
Postby Giovanni » Fri Jul 19, 2013 8:26 am
Moved in the GFX forum.
Postby Tectu » Fri Jul 19, 2013 10:48 am
Hello David,
  • In setpin_reset() in the gdisp_lld_board.h you flipped the both states. If state is set to true, the reset pin is supposed to be high, otherwise low. A proper documentation on this will follow shorty. The entire board file stuff is about to change in a few days to a more reliable solution.
  • Some people have reported problems that their MCU was toggling the pins to fast so the LCD controller couldn't properly detect the signals when they were using the PAL_STM32_OSPEED_HIGHEST macro.
  • Some poeple have reported problems that some e-bay distributors seem to mix up the ILI9320 and the ILI9325 driver. Please give the other one a try.
  • Usually you get some initialization code along with the display from your distributor. Try to replace it with the initialization code in the gdisp_lld_init() routine inside the gdisp_lld.c file.
  • Note that the CS pin is usually toggled using the spiSelect() and spiUnselect() calls.
  • Can you please post your gfxconf.h if all the steps above did not work.
Edit: Which STM32 discovery board are you using?
I hope that helps.
Postby Tectu » Mon Jul 22, 2013 12:15 am
Hello David,
As you can read here, you cannot post on this forum any longer. I search you to open a thread in the new forum. I am sorry for this trouble but it's a mandatory step.
