I'm trying nill out and if I call chThdSleepMilliseconds(250); in main it throws an unhandled excpetion, yet if I move the code into another thread and do not sleep in main I have no issue.
Any ideas?
chThdSleepMilliseconds in main possible?
- Has thanked: 1 time
- Been thanked: 20 times
Re: chThdSleepMilliseconds in main possible?
from demos/STM32/NIL-STM32F100-DISCOVERY/main.c
I guess that would also apply to any code you put under main().
Cheers,
Fabio Utzig
/* This is now the idle thread loop, you may perform here a low priority
task but you must never try to sleep or wait in this loop. Note that
this tasks runs at the lowest priority level so any instruction added
here will be executed after all other tasks have been started.*/
while (true) {
Cheers,
Fabio Utzig
- Has thanked: 1074 times
- Been thanked: 921 times
- Been thanked: 3 times
Is there any point in running `__WFI()` in the main() loop for Cortex-Mx?
Best regards,
Uli
Best regards,
Uli
Yes, placing _WFI in the loop improves power usage, it is not there by default because it can affect some debuggers.
