NIL without HAL Topic is solved
tfAteba
Has thanked: 91 times
Been thanked: 48 times
Postby tfAteba » Thu Dec 01, 2016 2:27 pm
Is it possible to use NIL without HAL ?
My target is an Arduino uno.
I want to use NIL for the RTOS mechanisms that it offer and want to use my own peripherals implementation.
So here is what I did:
I have bring up all file to have the NIL RTOS in my application. Here is the files:
- nil.c and .h
- nilconf.h
- niicore.c and .h
- niltypes.h
I also have a makefile and a main.c file.
I have include nil in my application and it build successfully.
The main use a thread to blink an LED:
 * Thread 2.
THD_WORKING_AREA(waThread1, 128);
THD_FUNCTION(Thread1, arg) {
  (void)arg;
  while (true) {
    PORTB &= ~(1 << 5);
    chThdSleepMilliseconds(500);
    PORTB |= (1 << 5);
    chThdSleepMilliseconds(2000);
But it don't work.
I think there is a problem of time that must be use to generate the chThdSleepMilliseconds delay but I'm not sure!
- Did I need to use another file for this?
- Is it possible to do that another way?
Thanks!
regards,
Theo.
Re: NIL without HAL
Postby Giovanni » Thu Dec 01, 2016 3:05 pm
Look at the demos \demos\various\NIL-ARMCM0-GENERIC or \demos\various\NIL-ARMCM4-GENERIC, it is just NIL without HAL.
You need to provide the system tick by yourself because that is usually provided by the HAL ST driver.
tfAteba
Re: NIL without HAL
Postby tfAteba » Thu Dec 01, 2016 3:14 pm
Ok, I was thinking about timer, I was not so far but not sure.
So I have to provide the system tick :) to make it work.
I will look at those example to understand what going on.
regards,
Theo.
Return to “ChibiOS/NIL”
