I have made some changes in debug plugin to support CDT DSF, so it works in Eclipse Oxygen.
Tested with JLink and Kernel version 4.
What kernel versions should plugin support?
Is Kernel version 5 compatible with version 4 from plugin view?
Debug plugin with DSF support
Re: Debug plugin with DSF support
vrollei wrote:Hi,
What kernel version should plugin support?
Will you be contributing your changes? If so, Yay! You're my hero, and thank you! Sorry, I can't answer your question though .
They are mostly the same, just some C expressions change. We may remove support for 2 and 3 because are closed branches but I would keep those if possible.
Giovanni,
expressions for v4 in attachment.
Could you please tell me which expressions are changed in v5.
Thanks!
Thanks!
- EXPv4.java.zip
- (1.08 KiB) Downloaded 240 times
Vitaly
v5 is exactly the same. You may duplicate it if you want a separate copy for each version but it is not really required. It is v2 and v3 that are different.
I don't like spending time writing Java much, there are a lot of things that could be improved/fixed/added in that plugin.
plugin sources are attached, v4 and v5 supported. v2 and v3 will be added later...
- org.chibios.tools.eclipse.debug.chibiosrt.zip
- (154.09 KiB) Downloaded 250 times
Vitaly
