Hi, I'm studying can communication.
I have STM32F4-Disc Board and did loopback test using files in 'testhal/STM32/CAN/*'. Checked LED blink, changed led
Now, I want to test using STM32F4-Disc's external header
Is there a test code about that? or reference homepage?
ChibiOS is hard to me, and I'm trying continue.
Below is thing I checked
In the datasheet,
CAN1_RX : PA11 / PB8 / PD0
CAN1_TX : PA12 / PB9 / PD0
(1) can't use PA11,12 cause the pins are used for OTG
(2) I'm testing PB8, 9 pins
CAN communication using STM32F4-Disc's external header
- Has thanked: 836 times
- Been thanked: 730 times
Re: CAN communication using STM32F4-Disc's external header
The F4 discovery board does not have CAN drivers, how are you planning to connect it?
You should get a board with CAN drivers and use that for your experimentation.
Thank you for reply Giovanni.
My target is to use CAN interface on F4 discovery board.
(found '2*CAN interface', in STM32F407 datasheet)
I have found that I need transceiver for CAN communication.
So, I planned test environment like below.
┌─── [transceiver_1] ─ (2) ─ [F4 Board_1]
│ (1)
└─── [transceiver_2] ─ (3) ─ [F4 Board_2]
* connections :
(1)
Can I test CAN communication in this situation?
│ (1)
* connections :
(1)
- transceiver_1's CAN_H ↔ transceiver_2's CAN_H
- transceiver_1's CAN_L ↔ transceiver_2's CAN_L
- F4 Board_1's PB8(CAN1_RX) ↔ transceiver_1's RX
- F4 Board_1's PB9(CAN1_TX) ↔ transceiver_1's TX
- F4 Board_2's PB8(CAN1_RX) ↔ transceiver_2's RX
- F4 Board_2's PB9(CAN1_TX) ↔ transceiver_2's TX
- F4 Board * 2
- transceiver * 2(CJMCU-2551*2 or WCMCU-230*2)
- 120Ω resistor, cables
Yes, keep wiring short and be careful to program GPIOs for CAN.
In the CAN demo you need to remove the loopback option from the configuration structure and it should work almost as-is. Note the all configurations come straight from the STM32 Reference Manual, make sure to read about the settings in the various registers.
Alright, Thank you.
I'll test with your advice and reply good result.
Users browsing this forum: Bing [Bot] and 5 guests
