[SOLVED] Problem libraries
ChibiOS public support forum for topics related to the STMicroelectronics SPC56x family of automotive micro-controllers.
GianlucaLaManna
Postby GianlucaLaManna » Fri Apr 03, 2015 3:31 pm
I have a problem with a function, sdStart () on board SPC560P.
I am using the test application ADC and would like to use the serial port for output (because I'm running a sensor).
I am using the test application ADC and would like to use the serial port to have a
Output Output (because I'm running a sensor).
I then modified the code of the test program by adding the function of the ADC sdStart (& SD1, NULL). The compiler me an error: SD1 undeclared. I also added the libraries
#include "serial.h"
#include "serial_lld.h"
This is my code
   SPC5 HAL - Copyright (C) 2013 STMicroelectronics
/* Inclusion of the main header files of all the imported components in the
   order specified in the application wizard. The file is generated
   automatically.*/
#include "components.h"
#include "adc_lld_cfg.h"
#include "serial.h"
 * Buffers used for the ADC conversions, note, the constants are defined
 * in adc_lld_cfg.h and are generated automatically.
static adcsample_t samples1[ADC0_GROUP_CFG0_NUM_CHANNELS *
                            ADC0_GROUP_CFG0_BUF_DEPTH];
static adcsample_t samples2[ADC1_GROUP_CFG0_NUM_CHANNELS *
                            ADC1_GROUP_CFG0_BUF_DEPTH];
 * ADC streaming callback, the name is defined in the ADC graphic
 * configuration.
size_t nx = 0, ny = 0;
void adc_conversion_callback(ADCDriver *adcp, adcsample_t *buffer, size_t n) {
  (void)adcp;
  if (samples2 == buffer) {
    nx += n;
  else {
    ny += n;
 * ADC error callback, the name is defined in the ADC graphic
 * configuration.
uint32_t errore = 30;
void adc_error_callback(ADCDriver *adcp, adcerror_t err) {
  (void)adcp;
  errore = err;
  palClearPad(PORT_A, Led_D11);
  osalSysHalt("ADC failure");
 * Application entry point.
int main(void) {
  /* Initialization of all the imported components in the order specified in
     the application wizard. The function is generated automatically.*/
  componentsInit();
  sdStart(&SD1, NULL);
  palSetPad(PORT_A,Led_D11);
  /* Starts the ADCD1, ADCD2 drivers.*/
  adcStart(&ADCD1, NULL);
  adcStart(&ADCD2, NULL);
  /* Linear conversion.*/
  adcConvert(&ADCD1, &adc0_group_cfg0,
             samples1, ADC0_GROUP_CFG0_BUF_DEPTH);
  osalThreadSleepMilliseconds(1000);
  /* Starts an ADC continuous conversion.*/
  adcStartConversion(&ADCD2, &adc1_group_cfg0,
                     samples2, ADC1_GROUP_CFG0_BUF_DEPTH);
  /* Normal main() thread activity, once the button is pressed the background
     ADC conversion is stopped.*/
  while (TRUE) {
     osalThreadSleepMilliseconds(100);
     palTogglePad(PORT_A,Led_D12);
But it does not work. Does anyone have an idea?
Best regards
Gianluca
Last edited by GianlucaLaManna on Fri Apr 03, 2015 4:52 pm, edited 1 time in total.
Re: Problem libraries
Postby Giovanni » Fri Apr 03, 2015 3:36 pm
You need to enable the serial driver in the "portable HAL" component and the LinFLEX1 in the "drivers component". All drivers and peripherals are disabled by default.
GianlucaLaManna
Postby GianlucaLaManna » Fri Apr 03, 2015 4:09 pm
Ok. I activated the serial connection in the file header halconf.h TRUE putting the line:
 #define HAL_USE_SERIAL              TRUE
Then I put in the file serial_lld.h TRUE line:
SPC5_SERIAL_USE_LINFLEX1            TRUE
The compiler says: SERIAL driver activated but no LINFlex peripheral assigned.
Postby Giovanni » Fri Apr 03, 2015 4:16 pm
This is done using the configuration tool, you shouldn't edit the configuration files manually.
GianlucaLaManna
Postby GianlucaLaManna » Fri Apr 03, 2015 4:35 pm
Ok. Sorry for my incompetence :oops: . I used the graphical tool. I checked the serial port and set LINFLEX1 of "serial". But it still does not work.
Postby Giovanni » Fri Apr 03, 2015 4:40 pm
My error, SD1 is LinFlex0.
GianlucaLaManna
Postby GianlucaLaManna » Fri Apr 03, 2015 4:44 pm
Yes. I had seen, as I compared the two files looking at the file that uses the serial port. This does not solve the problem. :(
Postby Giovanni » Fri Apr 03, 2015 4:48 pm
After configuring, you have to "generate" for the changes to have effect.
GianlucaLaManna
Postby GianlucaLaManna » Fri Apr 03, 2015 4:51 pm
Yeees. It works. Thank you so much. :mrgreen:
Gianluca.
Return to “SPC56x Support”
