How can I print an Integer
ChibiOS public support forum for topics related to the STMicroelectronics SPC56x family of automotive micro-controllers.
GianlucaLaManna
Postby GianlucaLaManna » Tue Jun 30, 2015 3:05 pm
Hello.
I use the board SPC560P-DISP.
How can I print an Integer with Tera Term through a serial connection?
I use the function chnWriteTimeout to print a string. So:
chnWriteTimeout(&SD1, (uint8_t *)"Hello World!\r\n", 14, TIME_INFINITE);
But an Integer?
I tried to use chprintf, but not working.
thanks.
Best regards
Gianluca
Has thanked: 1074 times
Been thanked: 921 times
Re: How can I print an Integer
Postby Giovanni » Tue Jun 30, 2015 3:09 pm
GianlucaLaManna wrote:I tried to use chprintf, but not working.
Define "not working".
GianlucaLaManna
Postby GianlucaLaManna » Tue Jun 30, 2015 3:22 pm
Yes. It does not recognize the function chprintf. I included the header chprintf.h
uint32_t number=25;
chprintf(&SD1, "%u \n\r", number);
The error is:
main.c:(.text_vle.main+0x10c): undefined reference to `chprintf'
collect2: ld returned 1 exit status
make: *** [build/out.elf] Error 1
Gianluca
Postby Giovanni » Tue Jun 30, 2015 3:26 pm
Is the "Output Formatter" component included in your project? chprintf is included there, it requires ChibiOS too.
GianlucaLaManna
Postby GianlucaLaManna » Tue Jun 30, 2015 3:36 pm
Sorry, I don't know and I don't understand.
This is my include in my code:
#include "components.h"
#include "adc_lld_cfg.h"
#include "pwm_lld_cfg.h"
#include "icu_lld_cfg.h"
I have to include something else? Or enable some option in the configuration.xml file?
Postby Giovanni » Tue Jun 30, 2015 3:54 pm
Please look at all the ChibiOS demos included in SPC5Studio, all of them use chprintf(). You could start from one of those demos for your experiments.
GianlucaLaManna
Postby GianlucaLaManna » Tue Jun 30, 2015 3:57 pm
Ok, but in the demo for my board using only chnWriteTimeout. Thanks anyway. :)
Gianluca.
GianlucaLaManna
[Solved] How can I print an Integer
Postby GianlucaLaManna » Tue Jul 07, 2015 11:47 am
I used os-less.
Now I use chibios.
I solved so:
chprintf((BaseSequentialStream *)&SD1, "Value of number is:  %d", number);
Best regards
Gianluca.
Return to “SPC56x Support”
