How use ICU Driver?
ChibiOS public support forum for topics related to the STMicroelectronics SPC56x family of automotive micro-controllers.
GianlucaLaManna
How use ICU Driver?
Postby GianlucaLaManna » Tue Jul 07, 2015 12:37 pm
I have to simulate the behavior of this function Arduino on Chibios for the management of my sensor.
duration = pulseIn(ECHO_PIN,HIGH);
I use ICU driver to detect the rising and falling edge.
This is the Arduino code:
Tested with HY-SRF05, HC-SR04
Assuming a room temp of 20 degrees centigrade
The circuit:
    * VVC connection of the sensor attached to +5V
    * GND connection of the sensor attached to ground
    * TRIG connection of the sensor attached to digital pin 12
        * ECHO connection of the sensor attached to digital pin 13
const int TRIG_PIN = 12;
const int ECHO_PIN = 13;
void setup() {
  // initialize serial communication:
  Serial.begin(9600);
  pinMode(TRIG_PIN,OUTPUT);
  pinMode(ECHO_PIN,INPUT);
void loop()
   long duration, distanceCm, distanceIn;
  // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
  digitalWrite(TRIG_PIN, LOW);
  delayMicroseconds(2);
  digitalWrite(TRIG_PIN, HIGH);
  delayMicroseconds(10);
  // convert the time into a distance
  distanceCm = duration / 29.1 / 2 ;
  distanceIn = duration / 74 / 2;
  if (distanceCm <= 0){
    Serial.println("Out of range");
  else {
    Serial.print(distanceIn);
    Serial.print("in, ");
    Serial.print(distanceCm);
    Serial.print("cm");
    Serial.println();
  delay(1000);
This is the code that I wrote, but something is wrong:
 ChibiOS/RT - Copyright (C) 2006-2014 Giovanni Di Sirio
/* Inclusion of the main header files of all the imported components in the
 order specified in the application wizard. The file is generated
 automatically.*/
#include "components.h"
#include "icu_lld_cfg.h"
icucnt_t last_width, last_period;
void icuwidthcb(ICUDriver *icup) {
  palSetPad(PORT_A, Led_D12);
  last_width = icuGetWidth(icup);
void icuperiodcb(ICUDriver *icup) {
  palClearPad(PORT_A, Led_D12);
  last_period = icuGetPeriod(icup);
 * LEDs blinker thread, times are in milliseconds.
static WORKING_AREA(waThread1, 128);
  (void)arg;
  chRegSetThreadName("detection");
  while (TRUE) {
     uint32_t duration, distanceCm;
       SIU.PCR[3].R =  0b0100010100000100;           /* PA3 alternate function.  */
       SIU.PCR[58].R = 0b0100010100000100;           /* PD10 alternate function.  */
          palClearPad(PORT_A, TRIG_PIN); // low
          osalThreadSleepMicroseconds(2);
          palSetPad(PORT_A, TRIG_PIN); //high
          osalThreadSleepMicroseconds(10);
          palTogglePad(PORT_A,Led_D12);
        icuStart(&ICUD4, &icu_config_icucfg);
        icuEnable(&ICUD4);
          palSetPad(PORT_A, ECHO_PIN); //high
        icuwidthcb(&ICUD4);
        icuperiodcb(&ICUD4);
          duration = last_width;
         chprintf((BaseSequentialStream *)&SD1,"Input Capture 3 Value is %u, %u\r\n", last_width, last_period);
         chprintf((BaseSequentialStream *)&SD1,"Distance cm: %u\r\n", distanceCm);
         icuDisable(&ICUD4);
         icuStop(&ICUD4);
          osalThreadSleepMilliseconds(2000);
           //chnWriteTimeout(&SD1, (uint8_t *)"%u\r\n", 14, TIME_INFINITE);
          //chprintf((BaseSequentialStream *)&SD1, "%u", duration);
          osalThreadSleepMilliseconds(500);
  return 0;
 * Application entry point.
int main(void) {
  /* Initialization of all the imported components in the order specified in
   the application wizard. The function is generated automatically.*/
  componentsInit();
  sdStart(&SD1, NULL);
   * Creates the detection thread.
    chThdSleepMilliseconds(1000);
I am getting output as 1, 1 only. What have I missed?
Are the callbacks?
Should I read the time that the signal Echo go back. How can I do? Is the right way?
Best regards
Gianluca
Re: How use ICU Driver?
Postby Giovanni » Tue Jul 07, 2015 3:13 pm
You are calling the "callbacks". Please see the demos in SPC5Studio and the HAL documentation.
Return to “SPC56x Support”
