Shell chThdCreateFromHeap + SPI does not work Topic is solved
error414
Has thanked: 3 times
Postby error414 » Sun Feb 21, 2021 11:30 am
I tried call "spiSend(&SPID4, 1, &data);" from shell command function, but it does not work.
static void cmd_spitest(BaseSequentialStream *chp, int argc, char *argv[]) {
   uint8_t data = 0x0b;
   spiSelect(&SPID4);
   spiUnselect(&SPID4);
I noticed that it works if I rewrite shell to static thread initialization.
Static shell initialization
Dynamic shell initialization
It sends 0x55, it's value for fill free space in thread stack, so it's definitely problem with pointer. See attachement with debug, there is right variable address in each step, M0AR register is set to right address to.
I have no clue what can be wrong. It seems that DMA cna't access to address, is it possible?
Test 1:
* Latest CHibiOs from github
* STM32F764Zi nucleo 144
1) compiled by CMAKE (gcc-arm-none-eabi-10-2020-q4-major)
2) compiled by MAKE (usedMakefile from chibios Demo, default gcc flags) (start_gcc90)
SPI does not work from dynamic created shell
Test 2:
* Latest ChibiOs from github
* STM32F401RE nucleo
SPI works from dynamic created shell
Re: Shell chThdCreateFromHeap + SPI does not work  Topic is solved
Postby Giovanni » Sun Feb 21, 2021 1:31 pm
On the F7 the stack is not DMA-accessible by default, place your buffers in static variables.
error414
Postby error414 » Sun Feb 21, 2021 2:14 pm
OMG, it's a such good support. Thank you very much to explain, I will keep shell static. No big deal.
Return to “General Support”
Users browsing this forum: No registered users and 57 guests
