LPC122x Port, tested on Olimex LPC-P1227 board
So far pal, gpt, serial and spi drivers are supported.
Zip file could be extracted in ChibiOS 2.5.2 root directory, and
then run make in directory demos\ARMCM0-LPC1227-OLIMEX.
LPC122x Port (Olimex LPC-P1227 board)
- OLIMEX_ LPC-P1227_ChibiOS_2.5.2.zip
- (70.47 KiB) Downloaded 536 times
Re: LPC122x Port (Olimex LPC-P1227 board)
Thanks for the contribute, the LPC maintainer "theShed" will consider this for inclusion.
New drivers for LPC122x:
I2C - only master mode support
EXT
PWM - 2 channels for each timer
RTC - don't support 10kHz input clock, only 1Hz
Testhal for RTC, EXT and PWM driver.
I've made few changes in chrtclib.c to support LPC122x RTC driver.
EXT
- OLIMEX_ LPC-P1227_ChibiOS_2.5.2_New_Drivers.zip
- (59.18 KiB) Downloaded 517 times
Added... Many thanks.
Giovanni - can you copy this thread to LPC Support please.
mike
mike
ADC - dma mode only support one selected channel,
all channels could be selected in interrupt mode
DMA - dma work with adc and memory to memory transfers
Testhal for ADC, ADC_DMA, DMA_MEM memory transfer.
Few changes in hall_lld.c, hall_lld.h to support DMA.
- OLIMEX_ LPC-P1227_ChibiOS_2.5.2_dma_adc.zip
- (50.5 KiB) Downloaded 486 times
Users browsing this forum: No registered users and 24 guests
