C++ on the AVR port Topic is solved
Moderators: utzig, tfAteba
mikenick42
Postby mikenick42 » Thu Feb 25, 2021 12:29 am
Has anyone had any luck with C++ on the AVR port of ChibiOS? I know the STM port can do it but when I try renaming main.c and moving it in the Makefile I get:
/usr/lib/avr/include/avr/io.h:623:6: warning: #warning "device type not defined" [-Wcpp]
 #    warning "device type not defined"
It looks like __AVR_ATmega328P__ isn't being defined for some reason.
Is it even worth using C++? I'm mainly interested in it because it makes encapsulation more convenient. What I want should be possible if I'm careful about how and where I declare things in C, but is a little cleaner in C++.
tfAteba
Has thanked: 91 times
Been thanked: 48 times
Re: C++ on the AVR port
Postby tfAteba » Mon Jun 14, 2021 1:33 pm
No I have never try to compile AVR code with C++ compiler.
regards,
Theo.
davidli
Postby davidli » Thu Jun 17, 2021 7:40 am
Maybe it only works under windows?
tfAteba
Postby tfAteba » Fri Jun 18, 2021 9:53 pm
Hello Davidli,
No it is not related to OS that you use.
Can yous share me the modification that you made in ChibiOS so that I can try to help.
regards,
Theo.
tfAteba
Postby tfAteba » Wed Nov 23, 2022 12:52 am
Hello Davidli,
I have take some time to look how to use C++ with AVR MCU.
As I said in this thread https://forum.chibios.org/posting.php?mode=reply&f=35&t=6125,
I have create a demo under demos/AVR/RT-ARDUINO-UNO-G++ to show how we can use C++.
It was due to the lac of CPP flags in the rules.mk file that is use to build our sources.
You can now use C or C++ 8-) .
regards,
Theo.
Return to “AVR Support”
