ch.rlist initialization with CH_CFG_NO_IDLE_THREAD
lungj
Postby lungj » Wed Apr 13, 2016 11:46 pm
It looks like if CH_CFG_NO_IDLE_THREAD is enabled, the thread ready list's next/prev values are set incorrectly. This causes problems when attempting to sleep: an invalid thread address is selected as the next element by queue_fifo_remove in chSchGoSleepS. Is this behaviour intentional?
int main(void) {
   while(1) {
      chThdSleepMilliseconds(1000); // This fails if CH_CFG_NO_IDLE_THREAD is TRUE.
   return 0;
Has thanked: 793 times
Been thanked: 685 times
Re: ch.rlist initialization with CH_CFG_NO_IDLE_THREAD
Postby Giovanni » Thu Apr 14, 2016 7:54 am
When CH_CFG_NO_IDLE_THREAD is enabled then the main() function is the idle thread, you must never try to sleep in there. Doing so causes the problems you are describing.
faisal
Has thanked: 35 times
Been thanked: 34 times
Postby faisal » Wed Apr 10, 2019 7:08 pm
Giovanni wrote:Hi,
Is this still the case? If so, there should be an assert somewhere to catch this. I think chSchGoSleepS is the right place.
Postby Giovanni » Wed Apr 10, 2019 8:57 pm
Yes, an assertion is a good idea.
Dzarda
Postby Dzarda » Thu Jan 07, 2021 2:06 pm
I got burned by this again, I think that an assertion should be very suitable.
Postby Giovanni » Thu Jan 07, 2021 2:29 pm
Moving into "bug reports" so it is not lost in the noise.
Return to “Bug Reports”
