Cortex-M0 bugs: 88167, 88656
RadaR
Postby RadaR » Wed Nov 06, 2019 8:49 pm
os/common/ports/ARMCMx/chcore_v6m.h
have check for GCC version
/* Handling a GCC problem impacting ARMv6-M.*/
#if defined(__GNUC__) && !defined(PORT_IGNORE_GCC_VERSION_CHECK)
#if __GNUC__ > 5
#warning "This compiler has a know problem with Cortex-M0, see bugs: 88167, 88656."
#warning "*** Use GCC version 5 or below ***"
From 25.10.2019 this bugs was fixed
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=88656
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=88167
Can you remove\updated this check in trunk version ?
Re: Cortex-M0 bugs: 88167, 88656
Postby Giovanni » Wed Nov 06, 2019 8:56 pm
It has been fixed on repositories but binary GCC distribution from ARM has still to include the fix, this will likely happen in next release.
The check cannot be removed, it needs to be updated but I need to know unaffected versions in each GCC branch.
RadaR
Postby RadaR » Wed Nov 06, 2019 11:36 pm
thanks
FXCoder
Has thanked: 180 times
Been thanked: 130 times
Postby FXCoder » Sun Mar 22, 2020 10:38 am
88167 & 88656 fixed on 2019-10-25 on all active branches.
GCC active branch releases subsequent to the fix...
GCC 7.5 [2019-11-14]
GCC 8.4 [2020-03-04]
GCC 9.3 [2020-03-12]
Bob
Postby Giovanni » Sun Mar 22, 2020 11:51 am
Thanks Bob,
Waiting the next ARM GCC release now...
alex31
Has thanked: 38 times
Been thanked: 62 times
Postby alex31 » Thu Mar 26, 2020 8:44 am
For the early testers, a guy maintains a bleeding edge toolchain where one can fin latest gcc 9.3, gdb 9.1 :
http://www.freddiechopin.info/en/downlo ... -toolchain
there is precompiled binaries for windows, but not for linux where there is only a build script.
If someone is interested, here is a link to a linux X64 build that should work on ubuntu (and derivatives like mint) 18.04 and after :
arm-none-eabi-gcc-9.3
I do not have M0 to test if bug is fixed, all i know is that it works for M4 (F4/F7), with significant lower binary size for c++ programs.
Alexandre
dflogeras
Has thanked: 7 times
Been thanked: 19 times
Postby dflogeras » Wed Apr 22, 2020 12:59 pm
Giovanni,
In previous situations like this, I've had success doing something like the following:
#if defined __GNUC__
 #if ( __GNUC__ > 5 ) && ( __GNUC__ < 10 )
  #define GCC_VERSION ( __GNUC__ * 10000 + __GNUC_MINOR__ * 100 + __GNUC_PATCHLEVEL__ )
  #if ( __GNUC__ == 7 ) && ( GCC_VERSION >= 70500 )
  #elif ( __GNUC__ == 8 ) && ( GCC_VERSION >= 80400 )
  #elif ( __GNUC__ == 9 ) && ( GCC_VERSION >= 90300 )
  #else
   #warn "Warning about version"
Postby Giovanni » Wed Apr 22, 2020 2:52 pm
I see, the problem right now is that the compiler is not yet released.
dflogeras
Postby dflogeras » Wed Apr 22, 2020 5:02 pm
Yup, I just wanted to throw that out there for the future, in case it helps you save some time.
Best,
Dave
Postby Giovanni » Sat Jun 06, 2020 7:51 am
Change committed and fixed as bug #985.
Return to “ChibiOS/RT”
Users browsing this forum: No registered users and 37 guests
