Hi Bob,
Please hold with the fix, I have not had time to really look into it but create the ticket.
Not sure about the memory leak, we should check in which version it disappeared. There have been no recent changes in the OSLIB/allocators that could explain this.
ChibiOS OS Library Test Suite
Re: ChibiOS OS Library Test Suite
Hi Bob,
The fix is not sufficient, it would align the size of the objects but the base address would not be necessarily aligned too, dyn_create_object_heap() requires an alignment parameter and should use chHeapAllocAligned() internally.
I am looking into it.
I committed a tentative fix in trunk, will be backported after some review.
- FXCoder
- Has thanked: 180 times
- Been thanked: 130 times
Have tested your current fix on a system that implements 2 x factory object FIFOs of different size and exercises all of the objects.
I forced the objects of one to be non-aligned and did not hit any assert or other problem so the fix looks good.
Although I've been using factory object FIFO in the above since factory was first released, the FIFOs of the system just happened to have object sizes which didn't trigger the alignment bug.
Just lucky on that.
Also have a project in development at work as well that is using multiple factory object FIFOs.
I'll update trunk of that project on Monday and test just to confirm.
Bob
Just lucky on that.
Bob
- FXCoder
Might the below be sufficient addition to oslib_test_sequence_009.c ?
The cleanup is left to oslib_test_009_005_teardown(...).
Bob
Bob
/* [9.5.7] Creating a dynamic objects FIFO with alignment of objects with
non-aligned size, must succeed.*/
test_set_step(7);
dofp = chFactoryCreateObjectsFIFO("myfifo", 13U, 16U, PORT_NATURAL_ALIGN);
test_assert(dofp != NULL, "cannot create");
test_end_step(7);
/* [9.5.8] Check alignment of base and next dynamic objects in FIFO,
must be aligned.*/
test_set_step(8);
void *obj1, *obj2;
objects_fifo_t * obfp = chFactoryGetObjectsFIFO(dofp);
test_assert(obfp != NULL, "no fifo allocated");
obj1 = chFifoTakeObjectTimeout(obfp, TIME_IMMEDIATE);
test_assert(obj1 != NULL, "no object 1 allocated");
test_assert(MEM_IS_ALIGNED(obj1, PORT_NATURAL_ALIGN),
"base of objects not aligned");
obj2 = chFifoTakeObjectTimeout(obfp, TIME_IMMEDIATE);
test_assert(obj2 != NULL, "no object 2 allocated");
test_assert(MEM_IS_ALIGNED(obj2, PORT_NATURAL_ALIGN),
"second object not aligned");
test_end_step(8);
Hi Bob,
chFactoryGetObjectsFIFO() cannot return NULL so it is not necessary to test it. The two chFifoTakeObjectTimeout() should fail because the FIFO is empty.
IMO the test is not very useful because the allocator always returns block aligned, at least, to PORT_NATURAL_ALIGN so it would never fail.
It is not easy to write such a test because the outcome depends on the current heap state, you would need to create initial conditions into the heap in order to explore the results (first fragment aligned to specific boundaries). Anyway you would be testing the allocator, not the factory code, it is the allocator that does the real alignment.
- FXCoder
Agreed it is the allocator doing the work under the hood that has to get things right.
The chFifoTakeObjectTimeout(...) call allocates an object from the pool (not receive from Mbox) and thus should not fail.
Anyway if the test isn't very useful then no problem.
Bob
Bob
run test against trunk version, it is the same situation:
00:00:38.314 DEBUG main.c::print_mem:51 - core free memory : 56112 bytes
00:00:38.342 DEBUG main.c::print_mem:52 - heap fragments : 2
00:00:38.367 DEBUG main.c::print_mem:53 - heap free total : 536 bytes
00:00:38.395 DEBUG main.c::print_mem:54 - heap free largest: 408 bytes
00:00:38.423 DEBUG main.c::main:194 - Iteration: 1 Errors: 0
00:08:43.114 DEBUG main.c::print_mem:51 - core free memory : 51120 bytes
00:08:43.142 DEBUG main.c::print_mem:52 - heap fragments : 1
00:08:43.168 DEBUG main.c::print_mem:53 - heap free total : 552 bytes
00:08:43.196 DEBUG main.c::print_mem:54 - heap free largest: 552 bytes
00:08:43.223 DEBUG main.c::main:194 - Iteration: 13 Errors: 0
Vitaly
Users browsing this forum: No registered users and 33 guests
