MFS using internal Flash
0x3333
Has thanked: 7 times
Been thanked: 6 times
Postby 0x3333 » Fri Mar 15, 2019 3:45 pm
In my first project using Chibios I have to store some parameters, small structure, containing 5 uint16_t entries., 10 bytes in total.
I'd like to use the internal flash to store these data, I'm using a STM32F103, so I don't want to attach a serial EEPROM or something. These parameters will not change for several months, eventually, it will, so internal flash seems a good option. STM32F103 has 128 pages(some 64 pages) with 1Kb each, so don't need to erase a big sector on writing.
I reserved the sectors on flash:
First 8KB bootloader, DAPBoot
Second 8KB Virtual EEPROM
The rest to Chibios app
MEMORY
    boot    : org = 0x08000000, len = 8K
    flash0  : org = 0x08004000, len = 112K
    eeprom  : org = 0x0801E000, len = 8K
I'm using a "driver" to write to flash, that I borrow from BOOTLOADER. So far so good.
I found out that Chibios has MFS, but using external flash chips, is there anyone that tried using internal flash? Is that a bad decision? Seems trivial to use it, just point functions to config and good to go.
In the weekend I'll try to workout something, but if is there anything that could go wrong, would be good to know in advance... :)
Has thanked: 843 times
Been thanked: 732 times
Re: MFS using internal Flash
Postby Giovanni » Fri Mar 15, 2019 5:24 pm
It should be able to work with internal flash but I need to integrate the flash driver first.
Anyway, use the MFS in trunk because I am still working on it and made fixes and improvements, it is not yet back-ported to 19.1.
0x3333
Postby 0x3333 » Fri Mar 15, 2019 7:30 pm
No problem, I'm working in trunk. I'm using Alex mirror in GitHub.
I'll try using my "driver", if it works, I'd like to ask some directions to write a STM32 internal flash driver if you believe is the right path.
Thanks again.
faisal
Has thanked: 35 times
Been thanked: 35 times
Postby faisal » Fri Mar 15, 2019 7:48 pm
0x3333 wrote:No problem, I'm working in trunk. I'm using Alex mirror in GitHub.
Thanks again.
Check this out: viewtopic.php?f=3&t=3524&start=10
It follows the BaseFlash abstraction that MFS uses, so should theoretically be compatible.
0x3333
Postby 0x3333 » Fri Mar 15, 2019 8:47 pm
Thanks again.
Great, I'll take a look. I'll probably adapt to F1, as it is a little simpler. Thanks!
faisal
Postby faisal » Fri Mar 15, 2019 8:56 pm
Thanks again.
Sure, go ahead and add support for the F1 to that driver. Post patches to the forum if you do :)
0x3333
Postby 0x3333 » Wed May 01, 2019 3:10 am
Just to inform, the patch with F1 flash driver support has been merged.
viewtopic.php?f=3&t=4323&start=30#p35276
Return to “ChibiOS/HAL”
