using lptim1 to wake from stop2
geoffrey.brown
Has thanked: 3 times
Been thanked: 11 times
Postby geoffrey.brown » Fri Mar 26, 2021 12:25 pm
This isn't an issue, more of a topic for more discussion. I've been building sub-gram dataloggers with stm32l4 processors for biologists studying songbirds. As you might image the biggest issue is energy -- getting a year out of a 5.5mAh battery is hard. A common use case is to power up a sensor, kick off a measurement and then wait for time to pass. During that waiting stop2 is ideal, the issue is waking. To do that I've been using the low power timer to trigger the wake up. Here's a code fragment illustrating how this works:
 // enable lptim1
    // Enter Stop2 mode
    RCC->APB1ENR1 |= (1 << 31);
    LPTIM1->CR = 1;
    // Set up compare,count registers
    LPTIM1->ARR = ms + 1;
    LPTIM1->CMP = ms; // set compare register
    LPTIM1->CNT = 0;  // reset counter
    // enable external event
    EXTI->EMR2 |= STM32_EXT_LPTIM1_LINE;
    // enable interrupts in lptim1
    LPTIM1->IER = STM32_LPTIM_IER_CMPMIE;
    LPTIM1->CFGR = 0;
    // Start the counter in single mode
    LPTIM1->CR |= STM32_LPTIM_CR_SNGSTRT;
    // go into stop2 mode
    DBGMCU->CR = 0;
    MODIFY_REG(PWR->CR1, PWR_CR1_LPMS, PWR_CR1_LPMS_STOP2);
    SET_BIT(SCB->SCR, ((uint32_t)SCB_SCR_SLEEPDEEP_Msk));
    __SEV();
    __WFE();
    __WFE();
    // disable lptim and interrupt/event
    EXTI->EMR2 &= ~STM32_EXT_LPTIM1_LINE;
    LPTIM1->IER = 0;
    LPTIM1->ICR = 1;
    LPTIM1->CR = 0;
    RCC->APB1ENR1 &= ~(1 << 31);
    CLEAR_BIT(SCB->SCR, ((uint32_t)SCB_SCR_SLEEPDEEP_Msk));
I should note that stop2 isn't perfect. I've found it necessary to disable/enable the SPI device before entering stop2. For reasons that I don't understand, i2c doesn't seem to require this. Also, I don't use the HAL spi driver with dma and all that -- in my application, the small amount of data transferred doesn't justify the overhead of setting up dma.
This seems to be a useful technique, but I admit my approach is completely ad-hoc and ripe for improvements
Geoffrey
Has thanked: 835 times
Been thanked: 730 times
Re: using lptim1 to wake from stop2
Postby Giovanni » Fri Mar 26, 2021 1:44 pm
Why the double __WFE() ?
geoffrey.brown
Postby geoffrey.brown » Fri Mar 26, 2021 5:59 pm
SEV
WFE
WFE
The SEV; WFE guarantees that there are no other events. I admit it seems strange, but I will say this idiom appears elsewhere -- for example the cube libraries.
It would be nice if there definitive guidance from ST on this
Geoffrey
Postby Giovanni » Fri Mar 26, 2021 6:23 pm
geoffrey.brown wrote:SEV
WFE
WFE
Geoffrey
It makes sense.
Return to “ChibiOS/HAL”
