I have found some little problems in Kinetis Demos:
Both RT-FREEDOM-K20D50M and RT-FREEDOM-KL25Z lack of ".project", ".cproject" and debug configuration.
Both RT-FREEDOM-K20D50M-EXT and RT-FREEDOM-KL25Z-EXT have broken debug configuration
These are minor fixes, but right now Demos are not ready to use.
Ciao,
RM
Little problems with Kinetis Demos
Moderator: utzig
- RoccoMarco
- Has thanked: 78 times
- Been thanked: 60 times
- Contact:
- Has thanked: 1 time
- Been thanked: 19 times
- Contact:
Re: Little problems with Kinetis Demos
I don't use any Eclipse based IDE to require .project, etc. If you want to send patches with the missing files/directories I would gladly add them. Btw, to debug I only create an openocd.cfg file with 4 lines in it (usually). I would expect users to do that if they need it.
Cheers,
Fabio Utzig
Cheers,
Fabio Utzig
- RoccoMarco
- Contact:
Hello utzig. I know what you mean, indeed, so I did. Anyway would be great if beginner user could be able to use you work with ease just installing ChibiStudio
I have attached a .zip containing all the project from /demos/KINETIS/ patched with .project .cproject and .launch. I hope this could be appreciated.
Ciao,
RM
Ciao,
RM
- KINETIS.zip
- (95.79 KiB) Downloaded 73 times
- RoccoMarco
- Contact:
