Has anyone explored porting ChibiOS to Freescale Kinetis Cortex M4 processors?
I am looking at this "Teensy 3.0" board http://www.kickstarter.com/projects/paulstoffregen/teensy-30-32-bit-arm-cortex-m4-usable-in-arduino-a.
I have used ChibiOS on AVR Arduino boards with the Arduino IDE by packaging ChibiOS as an Arduino library. I plan to try the same idea with Paul Stoffregen's Teensy 3.0 board.
Any advice for porting to Kinetis CM4 processors would be appreciated.
I have used ChibiOS on a number of Cortex boards and have ported other RTOSs like VxWorks to new processors/boards.
Port for Freescale Kinetis?
Moderator: utzig
- Has thanked: 1074 times
- Been thanked: 921 times
Re: Port for Freescale Kinetis?
Very nice small board.
The use of the kernel alone should be straightforward, you just need to create the files vectors.c, cmparams.h and the linker script under a ports/GCC/ARMCMs/Kinetis directory. Just follow the pattern of other devices presents there, you can have it working in minutes.
If you plan to start implementing an HAL then it is longer process, I recommend starting with a simple HAL driver (the clock tree settings are the most complex part), then simple PAL and Serial drivers. Supporting a single device is easy enough, it is more complex if you want to support the whole Kinetis family.
Supporting the whole family requires keeping a directory of shared device drivers, see the platforms/STM32 directory for example, and the have a single directory for each family member with the specific parts.
The problem is to define the internal interfaces between the "family code" and the device-specific code, for the STM32 several abstractions were required: clock, DMA, ISR.
I am in the middle of creating a similar "family" support structure for the SPC5xx/MPC5xxx devices and probably next I will do the same for the new Atmel cortex devices.
Please let me know if I can assist you in your effort, I already had plans for the new Kinetis L after the others I mentioned so it is something I was already considering.
I am interested in this too. I have just started looking at the code, and really like the idea of a good RTOS on this for simple projects.
Let me know what you get going, I need to carve out some time to work on this, but it would be nice to have others working on it also.
--Carl
--Carl
Just saying WOW the Freedom FRDM-KL25Z board (US$13 including onboard SWD debugger) and the MKL25Z128 (16K of RAM!) are really sweet in terms of features, pin count (80 pins!) and cost (MCU only about US$2.00 on Mouser in qty 100). I have been an STM32 fan in the past but it has fallen out of my favor for various reasons. I am starting to like this Kinetis L line.
If I start using Kinetis MCUs much, I would like to contribute to a ChibiOS/RT board for Kinetis. I don't have much experience or deep knowledge of the family yet, but I hope the KL (Kinetis L Cortex-M0+) and K series (Kinetis K10, K20, etc. Cortex-M4) have good compatible peripherals.
Thanks for your offer but I just received a freedom board , I am really looking forward to support it. It is next in queue after the SAM4L.
I am still an STM32 fan however
I'm glad to hear you'll be working on supporting the Kinetis L at some point!
I look forward to it.
Regards,
Colin
Regards,
Colin
sorry for being this late, but i found an old uVision Projekt for usage with the Kinetis KWIKSTIK-K40. Its just a Basic setup to get the MCU and ChibiOS running, but maybe it is usefull to someone.
Its a saml Sample of a Teatimer with some Threds and IPC working, as the Touch Perriperals. I there is any interrest i would like to hand over the files, may i find also the UART, GPIO and CAN Lowlevel drivers for the Chip along with the project.
If any interrest give some feedback.
Regards
CalM
Regards
CalM
Post it in the contributions forum, somebody could be looking exactly for that.
