russian wrote:is there a version of this without labels?
I have no such version and never used IAR.
int getRemainingStack(Thread *otp) {
#if CH_DBG_ENABLE_STACK_CHECK
register struct intctx *r13 asm ("r13");
otp->activeStack = r13;
int rs;
if (dbg_isr_cnt > 0) {
// ISR context
rs = (stkalign_t *) (r13 - 1) - &__main_stack_base__;
} else {
rs = (stkalign_t *) (r13 - 1) - otp->p_stklimit;
otp->remainingStack = rs;
return rs;
#else
return 99999;
#endif /* CH_DBG_ENABLE_STACK_CHECK */
#if CH_DBG_ENABLE_STACK_CHECK || defined(__DOXYGEN__)
int remainingStack;
remainingStack = 999; // todo
} else {
remainingStack = (stkalign_t *)(__get_SP() - sizeof(struct intctx)) - otp->p_stklimit;
otp->remainingStack = remainingStack;
return remainingStack;
#else
return 999999;
* @brief Switch to polling mode (disable interrupts)
* @param[in] sdp communication channel associated to the USART
void sd_lld_pollMode(SerialDriver *sdp) {
USART_TypeDef *u = sdp->usart;
u->CR1 &=
~(USART_CR1_TXEIE | USART_CR1_TCIE | USART_CR1_RXNEIE | USART_CR1_PEIE);
u->CR2 &= ~USART_CR2_LBDIE;
u->CR3 &= ~USART_CR3_EIE;
* @brief Output byte in polling mode
void sd_lld_xmitByte(SerialDriver *sdp, uint8_t b) {
while (!(u->SR & USART_SR_TXE)) ;
u->DR = b;
* If a serious error occurs, one of the fault
* exception vectors in this file will be called.
* This file attempts to aid the unfortunate debugger
* to blame someone for the crashing code
* Created on: 12.06.2013
* Author: uli
* Released under the CC0 1.0 Universal (public domain)
#include <stdint.h>
#include <ch.h>
#include <string.h>
// Can be uncommented to see backtrace.
#define DEBUG_BACKTRACE
* Executes the BKPT instruction that causes the debugger to stop.
* If no debugger is attached, this will be ignored
#define bkpt() __asm volatile("BKPT #0\n")
void NMI_Handler(void) {
//TODO
while(1);
//See http://infocenter.arm.com/help/topic/com.arm.doc.dui0552a/BABBGBEC.html
typedef enum {
Reset = 1,
NMI = 2,
HardFault = 3,
MemManage = 4,
BusFault = 5,
UsageFault = 6,
} FaultType;
/* On hard fault, copy FAULT_PSP to the sp reg so gdb can give a trace */
void **FAULT_PSP;
register void *stack_pointer asm("sp");
void HardFault_Handler(void) {
#ifdef DEBUG_BACKTRACE
asm("mrs %0, psp" : "=r"(FAULT_PSP) : :);
stack_pointer = FAULT_PSP;
// Here will be good to assert Error LED, like
// GPIOA->ODR |= 1;
while(1);
#else
//Copy to local variables (not pointers) to allow GDB "i loc" to directly show the info
//Get thread context. Contains main registers including PC and LR
struct port_extctx ctx;
memcpy(&ctx, (void*)__get_PSP(), sizeof(struct port_extctx));
//Interrupt status register: Which interrupt have we encountered, e.g. HardFault?
FaultType hf_faultType = (FaultType)__get_IPSR();
//(void)hf_faultType;
//For HardFault/BusFault this is the address that was accessed causing the error
uint32_t faultAddress = SCB->BFAR;
//(void)faultAddress;
//Flags about hardfault / busfault
//See http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0552a/Cihdjcfc.html for reference
bool isFaultPrecise = ((SCB->CFSR >> SCB_CFSR_BUSFAULTSR_Pos) & (1 << 1) ? true : false);
bool isFaultImprecise = ((SCB->CFSR >> SCB_CFSR_BUSFAULTSR_Pos) & (1 << 2) ? true : false);
bool isFaultOnUnstacking = ((SCB->CFSR >> SCB_CFSR_BUSFAULTSR_Pos) & (1 << 3) ? true : false);
bool isFaultOnStacking = ((SCB->CFSR >> SCB_CFSR_BUSFAULTSR_Pos) & (1 << 4) ? true : false);
bool isFaultAddressValid = ((SCB->CFSR >> SCB_CFSR_BUSFAULTSR_Pos) & (1 << 7) ? true : false);
// This is to prevent variables to be optimized out
if ((ctx.r0 != ctx.r1) && (ctx.xpsr != ctx.pc) && (faultAddress != 2))
asm("nop");
if (hf_faultType != 2)
asm("nop");
if (isFaultPrecise)
asm("nop");
if (isFaultImprecise)
asm("nop");
if (isFaultOnUnstacking)
asm("nop");
if (isFaultOnStacking)
asm("nop");
if (isFaultAddressValid)
asm("nop");
if ( hf_faultType)
asm("nop");
//Cause debugger to stop. Ignored if no debugger is attached
bkpt();
NVIC_SystemReset();
void BusFault_Handler(void) __attribute__((alias("HardFault_Handler")));
void UsageFault_Handler(void) {
while(1);
#else
(void)ctx;
FaultType faultType = (FaultType)__get_IPSR();
(void)faultType;
bool isUndefinedInstructionFault = ((SCB->CFSR >> SCB_CFSR_USGFAULTSR_Pos) & (1 << 0) ? true : false);
bool isEPSRUsageFault = ((SCB->CFSR >> SCB_CFSR_USGFAULTSR_Pos) & (1 << 1) ? true : false);
bool isInvalidPCFault = ((SCB->CFSR >> SCB_CFSR_USGFAULTSR_Pos) & (1 << 2) ? true : false);
bool isNoCoprocessorFault = ((SCB->CFSR >> SCB_CFSR_USGFAULTSR_Pos) & (1 << 3) ? true : false);
bool isUnalignedAccessFault = ((SCB->CFSR >> SCB_CFSR_USGFAULTSR_Pos) & (1 << 8) ? true : false);
bool isDivideByZeroFault = ((SCB->CFSR >> SCB_CFSR_USGFAULTSR_Pos) & (1 << 9) ? true : false);
(void)isUndefinedInstructionFault;
(void)isEPSRUsageFault;
(void)isInvalidPCFault;
(void)isNoCoprocessorFault;
(void)isUnalignedAccessFault;
(void)isDivideByZeroFault;
bkpt();
NVIC_SystemReset();
void MemManage_Handler(void) {
while(1);
#else
(void)ctx;
(void)faultType;
uint32_t faultAddress = SCB->MMFAR;
(void)faultAddress;
bool isInstructionAccessViolation = ((SCB->CFSR >> SCB_CFSR_MEMFAULTSR_Pos) & (1 << 0) ? true : false);
bool isDataAccessViolation = ((SCB->CFSR >> SCB_CFSR_MEMFAULTSR_Pos) & (1 << 1) ? true : false);
bool isExceptionUnstackingFault = ((SCB->CFSR >> SCB_CFSR_MEMFAULTSR_Pos) & (1 << 3) ? true : false);
bool isExceptionStackingFault = ((SCB->CFSR >> SCB_CFSR_MEMFAULTSR_Pos) & (1 << 4) ? true : false);
bool isFaultAddressValid = ((SCB->CFSR >> SCB_CFSR_MEMFAULTSR_Pos) & (1 << 7) ? true : false);
(void)isInstructionAccessViolation;
(void)isDataAccessViolation;
(void)isExceptionUnstackingFault;
(void)isExceptionStackingFault;
(void)isFaultAddressValid;
bkpt();
NVIC_SystemReset();
