[DEV] RP2040 support
steved
Has thanked: 10 times
Been thanked: 120 times
Re: [NOTES] Multi Core support
Postby steved » Wed Jan 27, 2021 9:40 pm
This commit suggests that:
a) You need the RPi version of openOCD to support multiple processors
b) Only bitbang and FTDI-style serial interfaces are supported at present. Is ST-Link fundamentally serial?
Clearly aimed at using a Raspberry Pi as the debug interface initially; possibly other platforms also work
On a quick look I couldn't see that RPi had pushed their changes back to the main OpenOCD repository; certainly the script files weren't there.
The Pi Foundation have a policy of not releasing information in advance of real product; then on launch day there's a whole lot of updates to documentation and so on all at once. OpenOCD probably isn't a high priority ATM; I'm sure the updates will be pushed in due course
FXCoder
Has thanked: 156 times
Been thanked: 118 times
Postby FXCoder » Wed Jan 27, 2021 11:08 pm
Don't see any RP2040 based submissions on the openocd gerrit site.
(Gerrit process is required before for getting to commit on openocd SF master).
Anyway early days yet for the pico so maybe asking Liam Fraser might reveal something?
Bob
Has thanked: 835 times
Been thanked: 730 times
[DEV] RP2040 Support
Postby Giovanni » Thu Jan 28, 2021 10:00 am
Hopefully they will send their OpenOCD changes upstream, it would be difficult to have to handle multiple OpenOCD implementations.
Postby Giovanni » Thu Jan 28, 2021 6:39 pm
I studied the DS a little bit and I must say that this device is interesting, I am impressed for a "first device" from a small company.
Everything seems to be fine for a ChibiOS port, the timer is perfect for tickless more and RT time (monotonic 64 bits counter and comparators). DMA seems to not have an "half buffer" interrupt so implementing the ADC driver could be a little complex because it would need to leverage channels linking probably.
Dual core support looks good but I have not yet found a way for a core to notify the other core through an interrupt, this is required if one core makes a thread belonging to the other core "ready", it needs to notify the other core that its ready list has been updated and a reschedule is required. Maybe this is possible using the FIFOs, I have to study this some more.
They did a lot of work on the SW side, the port should be done in a way that enhances the ecosystem in order to leverage it, for sure I don't want to be too "alternative" in this case.
Ludeks
Has thanked: 3 times
Postby Ludeks » Fri Jan 29, 2021 12:11 am
That's great news to hear! :)
With regards to the multi core communication, the cores are interconnected through 2 FIFOs, writing to the FIFO from one core can raise an interrupt on the other core.
See section 2.3.1.4. Inter-processor FIFOs (Mailboxes)
Each FIFO is 32 bits wide, and eight entries deep. One of the FIFOs can only be written by core 0, and read by core 1. The other can only be written by core 1, and read by core 0.
The SIO has a FIFO IRQ output for each core, mapped to system IRQ numbers 15 and 16.
If the corresponding interrupt line is enabled in the Cortex-M0+ NVIC, then the processor will take an interrupt each time data appears in its FIFO, or if it has performed some invalid FIFO operation (read on empty, write on full). Typically Core 0 will use IRQ15 and core 1 will use IRQ16.
Postby Giovanni » Fri Jan 29, 2021 3:40 pm
Well, first problems:
1) No CMSIS files anywhere in the SDK, headers would have to be created. The SDK is entirely custom so hardly compatible with anything. Their IRQ system is custom (IRQ chains for shared interrupts) and it is not compatible with an RTOS which requires its code in handlers, this is an extra problem.
2) I tried to build the blinker demo following the "getting started" document and it failed, with an asm error:
giovanni@Freya:~/Projects/pico/pico-examples/build/blink$ make
[  0%] Creating directories for 'ELF2UF2Build'
[  0%] No download step for 'ELF2UF2Build'
[  0%] No patch step for 'ELF2UF2Build'
[  0%] No update step for 'ELF2UF2Build'
[  0%] Performing configure step for 'ELF2UF2Build'
-- Configuring done
-- Generating done
-- Build files have been written to: /home/giovanni/Projects/pico/pico-examples/build/elf2uf2
[  0%] Performing build step for 'ELF2UF2Build'
[100%] Built target elf2uf2
[  0%] No install step for 'ELF2UF2Build'
[  0%] Completed 'ELF2UF2Build'
[  0%] Built target ELF2UF2Build
[  0%] Built target bs2_default
[  0%] Built target bs2_default_bin
[  0%] Built target bs2_default_padded_checksummed_asm
[  0%] Building C object blink/CMakeFiles/blink.dir/blink.c.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/rp2_common/pico_stdlib/stdlib.c.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/rp2_common/hardware_gpio/gpio.c.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/rp2_common/hardware_claim/claim.c.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/rp2_common/hardware_sync/sync.c.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/rp2_common/pico_platform/platform.c.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/rp2_common/hardware_uart/uart.c.obj
[  0%] Building ASM object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/rp2_common/hardware_divider/divider.S.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/common/pico_time/time.c.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/common/pico_time/timeout_helper.c.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/rp2_common/hardware_timer/timer.c.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/common/pico_sync/sem.c.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/common/pico_sync/lock_core.c.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/common/pico_sync/mutex.c.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/common/pico_sync/critical_section.c.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/common/pico_util/datetime.c.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/common/pico_util/pheap.c.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/common/pico_util/queue.c.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/rp2_common/pico_runtime/runtime.c.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/rp2_common/hardware_clocks/clocks.c.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/rp2_common/hardware_watchdog/watchdog.c.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/rp2_common/hardware_xosc/xosc.c.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/rp2_common/hardware_pll/pll.c.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/rp2_common/hardware_vreg/vreg.c.obj
[  0%] Building C object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/rp2_common/hardware_irq/irq.c.obj
[  0%] Building ASM object blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/rp2_common/hardware_irq/irq_handler_chain.S.obj
/home/giovanni/Projects/pico/pico-sdk/src/rp2_common/hardware_irq/irq_handler_chain.S: Assembler messages:
/home/giovanni/Projects/pico/pico-sdk/src/rp2_common/hardware_irq/irq_handler_chain.S:54: Error: bad instruction `u'
/home/giovanni/Projects/pico/pico-sdk/src/rp2_common/hardware_irq/irq_handler_chain.S:54: Error: junk at end of line, first unrecognized character is `u'
make[2]: *** [blink/CMakeFiles/blink.dir/build.make:380: blink/CMakeFiles/blink.dir/home/giovanni/Projects/pico/pico-sdk/src/rp2_common/hardware_irq/irq_handler_chain.S.obj] Error 1
make[1]: *** [CMakeFiles/Makefile2:3493: blink/CMakeFiles/blink.dir/all] Error 2
make: *** [Makefile:84: all] Error 2
Not sure what is this about, the build system is very complex and I have not figured out what command has been executed and its options. It seems to assume you are using an RPI for development, probably it is not compatible with Mint/Ubuntu.
This thing will have to wait, too much time spent with no LED blinking yet.
Postby Giovanni » Fri Jan 29, 2021 10:59 pm
At least the build problem is solved, I have GCC 5.4.1 as default, it needs a more recent version.
steved
Postby steved » Fri Jan 29, 2021 11:59 pm
Giovanni wrote:At least the build problem is solved, I have GCC 5.4.1 as default, it needs a more recent version.
They apparently tested with a range of compilers, but not that old!
Latest wisdom is that current ST-Link won't support multi-processor without ST upgrading it. JLink works. And you can also use another Pico (see Appendix A of "getting started").
steved
Postby steved » Sat Jan 30, 2021 10:53 am
This guy is doing bare-metal stuff on the Pico (and the Pi) - might be some useful pointers to getting things going. This thread covers the first attempts.
steved
Postby steved » Sat Jan 30, 2021 6:36 pm
Giovanni wrote:Well, first problems:
All the header files for the chip are in pico-sdk-master\src\rp2040 - can they be used 'as is', at least until the next device in the family comes out?
