error CAN settings in HAL example
Alexte
Post by Alexte »
testhal\STM32\STM32F1xx\CAN\main.c
 * Internal loopback mode, 500KBaud, automatic wakeup, automatic recover
 * from abort mode.
 * See section 22.7.7 on the STM32 reference manual.
static const CANConfig cancfg = {
  CAN_MCR_ABOM | CAN_MCR_AWUM | CAN_MCR_TXFP,
  CAN_BTR_LBKM | CAN_BTR_SJW(0) | CAN_BTR_TS2(1) |
  CAN_BTR_TS1(8) | CAN_BTR_BRP(6)
with these settings speed CAN bus ~ 428 kBaud
CAN_BTR_BRP=5 speed 500 kBaud
Re: error CAN settings in HAL example
I will fix it.
BTW, this calculator can be used: http://www.bittiming.can-wiki.info/
Alexte
Post by Alexte »
I just started with this calculator, it is the same error :)
I am attaching the file correct calculation...
STM32_CAN_speed_calc.zip
(33.49 KiB) Downloaded 553 times
bump
bitto
Post by bitto »
Hello.
Just to see I'm doing it right: this configuration yields 1 Mbit/s on my STM32-H107 Olimex board?
static const CANConfig cancfg_1MBit = {
                                       CAN_BTR_SJW(0) | CAN_BTR_TS2(2) |
                                       CAN_BTR_TS1(13) | CAN_BTR_BRP(1)
Thanks in advance.
Alberto
If you used the calculator and if your clock settings are right (mcuconf.h) then yes. A real confirmation would require a test.
Last bumped by Giovanni on Sun Nov 10, 2019 10:22 am.
