WDG for stm32F0 - certified / tested? Topic is solved
nullbert
Postby nullbert » Fri Sep 02, 2016 7:32 pm
I'm attempting to get the watchdog timer working on an STM32F072. Here's what I see:
* The watchdog does reset periodically as expected.
* However, wdgReset() seems to hang the system, or cause an immediate reset - hard to immediately tell.
Has the wdgTimer() been tested / certified for the STM32F0 ? I did not see it listed in the testhal for this processor.
I've enabled it both in the mcuconf.h and halconf.h and implemented it simply in my main.c:
#define MAIN_THREAD_SLEEP_MS 1000
#define WATCHDOG_TIMEOUT 1000
/* Watchdog configuration and initialization
static void start_watchdog(void)
    const WDGConfig wdgcfg = {
            STM32_IWDG_PR_64,
          STM32_IWDG_RL(WATCHDOG_TIMEOUT)
    wdgStart(&WDGD1, &wdgcfg);
int main(void) {
   start_watchdog();
   while (true) {
      chThdSleepMilliseconds(MAIN_THREAD_SLEEP_MS);
      wdgReset(&WDGD1);
   return 0;
Thanks for any help.
Re: WDG for stm32F0 - certified / tested?
Postby Giovanni » Fri Sep 02, 2016 8:49 pm
It has not yet been tested on F0 (or it would have a demo), moving the the bug report section.
Postby Giovanni » Mon Oct 03, 2016 11:19 am
Bumped.
Re: WDG for stm32F0 - certified / tested?  Topic is solved
Postby Giovanni » Tue Oct 04, 2016 10:47 am
I added a WDG demo for the STM32F0, apparently it works as-is, there must be another cause for the behavior you observed.
The demo is in repository trunk but it should be portable to 16.1.
nullbert
Postby nullbert » Sat Nov 26, 2016 4:54 am
Thank you, we'll check it out.
Return to “Bug Reports”
Users browsing this forum: No registered users and 54 guests
