Nil: system clock failed to restart from 0 Topic is solved
aGuegu
Been thanked: 5 times
Postby aGuegu » Thu Dec 07, 2017 5:28 pm
Running test with ChibiOS svn revison: 11133
Platform: STM32F103C8_MINIMAL (stm32c8t6)
Toolchain: gcc-arm-none-eabi-6-2017-q2-update
#include "ch.h"
#include "chprintf.h"
THD_WORKING_AREA(waThread1, 32);
THD_FUNCTION(Thread1, arg) {
  (void)arg;
  palSetPadMode(GPIOC, GPIOC_LED, PAL_MODE_OUTPUT_OPENDRAIN);
  while (true) {
    palTogglePad(GPIOC, GPIOC_LED);
    chThdSleepMilliseconds(250);
THD_WORKING_AREA(waThread2, 128);
THD_FUNCTION(Thread2, arg) {
  (void)arg;
  uint8_t buff;
  BaseSequentialStream* chp = (BaseSequentialStream*) &SD1;
  sdStart(&SD1, NULL);
  palSetPadMode(GPIOA, 9, PAL_MODE_STM32_ALTERNATE_OPENDRAIN);       // USART1 TX
  palSetPadMode(GPIOA, 10, PAL_MODE_INPUT);                          // USART1 RX
  while (true) {
    uint8_t len = sdReadTimeout(&SD1, &buff, 1, 500);
    if (len) {
      chprintf(chp, "%02x\r\n", buff);
    } else {
      chnWrite(&SD1, (const uint8_t *)"Hello World, ", 13);
      chprintf(chp, "%u\r\n", chVTGetSystemTimeX());
THD_TABLE_BEGIN
  THD_TABLE_ENTRY(waThread1, "blinker1", Thread1, NULL)
  THD_TABLE_ENTRY(waThread2, "hello", Thread2, NULL)
THD_TABLE_END
int main(void) {
  while(1) {
  return 0;
If you want to check other files like chconf.h, the code repo is https://github.com/aguegu/stm32-bluepil ... /nil-hello .
It is a simple demo. While onboard led is blinking, SD1 prints the 'hello, world' and the system time. If SD1 read chars within 500 ms, it will echo the input in hex mode.
At first, it runs okay. if I did not type in any character. The system timer would restart from zero when it overflows.
But if I typed a few keys, the hex output works, when the system timer close to its maximum, like 65071, it failed to restart, and the led stop blinking.
It looks like the system is halting.
aGuegu
Re: Nil: system clock failed to restart from 0
Postby aGuegu » Fri Dec 08, 2017 4:28 am
I rebuilt this code with Release 17.6.3, it works fine.
Has thanked: 1118 times
Been thanked: 938 times
Postby Giovanni » Fri Dec 08, 2017 4:58 pm
The problem is confirmed, I am working on it.
You can mitigate it by setting CH_CFG_INTERVALS_SIZE to 16 in chconf.h. It does not affect released versions, only trunk.
aGuegu
Postby aGuegu » Fri Dec 08, 2017 6:40 pm
cool, happy to help. :D
Postby Giovanni » Sat Dec 09, 2017 11:07 am
It should be fixed now. My previous suggestion was wrong, CH_CFG_INTERVALS_SIZE does not work with NIL (removed it).
aGuegu
Postby aGuegu » Mon Dec 11, 2017 5:11 pm
Yes, my hello demo works with SVN revision: 11139. Well done.
Return to “Bug Reports”
