Segmentation fault (core dumped) Topic is solved
tfAteba
Has thanked: 81 times
Been thanked: 46 times
Postby tfAteba » Sun Dec 24, 2017 2:23 am
Hello All,
Currently, I'm interresting on ChibiOS test suite, and to make a test under my linux computer, I have try the following demos:
/demos/various/RT-Posix-Simulator
Because of the usage of 32bits while compiling on my 64bits, as shows on line 8 of the makefile (USE_OPT = -O2 -ggdb -m32).
I had this error during the compilation (fatal error: sys/cdefs.h: No such file or directory).
This error is solved by installing some packages: sudo apt-get install gcc-multilib g++-multilib
After the building, I then ran the command build/ch on one terminal. That gives me the two ports that can be used to connect on.
So on the other terminal i ran telnet localhost 29001 and test rt that gives me the following result:
test rt
*** ChibiOS/RT Test Suite
*** Compiled:     Dec 24 2017 - 00:58:21
*** Platform:     Posix Simulator
=== Test Sequence 1 (Information)
--- Test Case 1.1 (Port Info)
--- Architecture:                       Simulator
--- Core Variant:                       x86 (integer only)
--- Compiler:                           GCC 5.4.0 20160609
--- Port Info:                          No preemption
--- Natural alignment:                  4
--- Stack alignment:                    16
--- Working area alignment:             16
--- Result: SUCCESS
--- Test Case 1.2 (Kernel Info)
--- Product:                            ChibiOS/RT
--- Stable Flag:                        0
--- Version String:                     5.0.0
--- Major Number:                       5
--- Minor Number:                       0
--- Patch Number:                       0
--- Result: SUCCESS
--- Test Case 1.3 (Kernel Settings)
--- CH_CFG_ST_RESOLUTION:               32
--- CH_CFG_ST_FREQUENCY:                1000
--- CH_CFG_INTERVALS_SIZE:              32
--- CH_CFG_TIME_TYPES_SIZE:             32
--- CH_CFG_ST_TIMEDELTA:                0
--- CH_CFG_TIME_QUANTUM:                0
--- CH_CFG_MEMCORE_SIZE:                131072
--- CH_CFG_NO_IDLE_THREAD:              0
--- CH_CFG_OPTIMIZE_SPEED:              1
--- CH_CFG_USE_TM:                      1
--- CH_CFG_USE_REGISTRY:                1
--- CH_CFG_USE_WAITEXIT:                1
--- CH_CFG_USE_SEMAPHORES:              1
--- CH_CFG_USE_SEMAPHORES_PRI:          0
--- CH_CFG_USE_MUTEXES:                 1
--- CH_CFG_USE_MUTEXES_RECURS:          0
--- CH_CFG_USE_CONDVARS:                1
--- CH_CFG_USE_CONDVARS_TIMEO:          1
--- CH_CFG_USE_EVENTS:                  1
--- CH_CFG_USE_EVENTS_TIMEOUT:          1
--- CH_CFG_USE_MESSAGES:                1
--- CH_CFG_USE_MESSAGES_PRI:            0
--- CH_CFG_USE_MAILBOXES:               1
--- CH_CFG_USE_MEMCORE:                 1
--- CH_CFG_USE_HEAP:                    1
--- CH_CFG_USE_MEMPOOLS:                1
--- CH_CFG_USE_OBJ_FIFOS:               1
--- CH_CFG_USE_DYNAMIC:                 1
--- CH_CFG_USE_FACTORY:                 1
--- CH_CFG_FACTORY_MAX_NAMES_LENGTH:    8
--- CH_CFG_FACTORY_OBJECTS_REGISTRY:    1
--- CH_CFG_FACTORY_GENERIC_BUFFERS:     1
--- CH_CFG_FACTORY_SEMAPHORES:          1
--- CH_CFG_FACTORY_MAILBOXES:           1
--- CH_CFG_FACTORY_OBJ_FIFOS:           1
--- CH_DBG_STATISTICS:                  0
--- CH_DBG_SYSTEM_STATE_CHECK:          0
--- CH_DBG_ENABLE_CHECKS:               0
--- CH_DBG_ENABLE_ASSERTS:              0
--- CH_DBG_TRACE_MASK:                  255
--- CH_DBG_TRACE_BUFFER_SIZE:           128
--- CH_DBG_ENABLE_STACK_CHECK:          0
--- CH_DBG_FILL_THREADS:                0
--- CH_DBG_THREADS_PROFILING:           0
--- Result: SUCCESS
=== Test Sequence 2 (System layer and port interface)
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Test Case 2.4 (System Tick Counter functionality)
--- Result: SUCCESS
=== Test Sequence 3 (Threads Functionality)
--- Test Case 3.1 (Thread Sleep functionality)
--- Result: SUCCESS
--- Test Case 3.2 (Ready List functionality, threads priority order)
--- Result: SUCCESS
--- Test Case 3.3 (Priority change test)
--- Result: SUCCESS
--- Test Case 3.4 (Priority change test with Priority Inheritance)
--- Result: SUCCESS
=== Test Sequence 4 (Suspend/Resume)
--- Test Case 4.1 (Suspend and Resume functionality)
--- Result: SUCCESS
=== Test Sequence 5 (Counter Semaphores)
--- Test Case 5.1 (Semaphore primitives, no state change)
--- Result: SUCCESS
--- Test Case 5.2 (Semaphore enqueuing test)
--- Result: SUCCESS
--- Test Case 5.3 (Semaphore timeout test)
--- Result: SUCCESS
--- Test Case 5.4 (Testing chSemAddCounterI() functionality)
--- Result: SUCCESS
--- Test Case 5.5 (Testing chSemWaitSignal() functionality)
--- Result: SUCCESS
--- Test Case 5.6 (Testing Binary Semaphores special case)
--- Result: SUCCESS
=== Test Sequence 6 (Mutexes, Condition Variables and Priority Inheritance)
--- Test Case 6.1 (Priority enqueuing test)
--- Result: SUCCESS
--- Test Case 6.2 (Priority return verification)
--- Result: SUCCESS
--- Test Case 6.3 (Repeated locks, non recursive scenario)
--- Result: SUCCESS
--- Test Case 6.4 (Condition Variable signal test)
--- Result: SUCCESS
--- Test Case 6.5 (Condition Variable broadcast test)
--- Result: SUCCESS
--- Test Case 6.6 (Condition Variable priority boost test)
--- Result: SUCCESS
=== Test Sequence 7 (Synchronous Messages)
--- Test Case 7.1 (Messages Server loop)
--- Result: SUCCESS
=== Test Sequence 8 (Event Sources and Event Flags)
--- Test Case 8.1 (Events registration)
--- Result: SUCCESS
--- Test Case 8.2 (Event Flags dispatching)
--- Result: SUCCESS
--- Test Case 8.3 (Events Flags wait using chEvtWaitOne())
--- Result: SUCCESS
--- Test Case 8.4 (Events Flags wait using chEvtWaitAny())
--- Result: SUCCESS
--- Test Case 8.5 (Events Flags wait using chEvtWaitAll())
--- Result: SUCCESS
--- Test Case 8.6 (Events Flags wait timeouts)
--- Result: SUCCESS
--- Test Case 8.7 (Broadcasting using chEvtBroadcast())
--- Result: SUCCESS
=== Test Sequence 9 (Dynamic threads)
--- Test Case 9.1 (Threads creation from Memory Heap)
Connection closed by foreign host.
And on the other terminal, here is what we had: Init:
disconnection on SD1
For the moment this is just a report, I will try to resolver this error for next time.
regards,
Theo.
faisal
Has thanked: 35 times
Been thanked: 34 times
Re: Segmentation fault (core dumped)
Postby faisal » Mon May 11, 2020 1:30 am
The simulator is segfaulting at the tip of development branch, but works fine in stable_20.3.x.
The segfault seems to happen in the context switch..
faisal
Postby faisal » Mon May 11, 2020 3:21 am
I did some more digging around with git bisect, and I found the offending commit:
https://osdn.net/projects/chibios/scm/svn/commits/13496
I'm guessing it has something to do with moving around the struct port_context in the thread structure.
Has thanked: 785 times
Been thanked: 679 times
Postby Giovanni » Mon May 11, 2020 3:31 am
Thanks, yes, that must be it.
Postby Giovanni » Mon May 18, 2020 5:30 pm
Fixed in trunk.
Return to “Bug Reports”
