This bug pertains to the documentation of the CANFilter struct. The .filter field states that the field is for the "Number of the filter to be programmed". This is true when .scale is 1 (32-bit filters) and .mode is 1 (mask mode); however, it is false when .scale and/or .mode are/is 0. One filter bank contains more than one filter (which are numbered by "filter number" by ST on, for example, figure 393 of RM0390 Revision 4) when 16-bit filters are used and/or when the CAN filter is using identifier mode.
Proposed change to use ST's terminology: "Number of the filter bank to be programmed."
(Also, both registers 1 and 2 may also contain mask AND identifier when .filter = 1 and .scale = 0; the documentation for .register1 states that it is the identifier and that .register2 is the mask/identifier depending on mode)
CANFilter struct documentation bug Topic is solved
Users browsing this forum: No registered users and 56 guests
