I am using ChibiOS 20.3, stm32F4, and need to use DAC in 8 bits mode. Although is work well in 12 bits mode, half buffer callback is called twice as it should in DAC_DHRM_8BIT_RIGHT mode, no dual channel, only one channel used.
The code of the hal is complex because there is conditionnal compilation for all the possible mode (dual mode or not, many channel or not), but in my case, i resolved my bug with that fix :
diff --git a/os/hal/ports/STM32/LLD/DACv1/hal_dac_lld.c b/os/hal/ports/STM32/LLD/DACv1/hal_dac_lld.c
index b4180d36c..91be17efd 100644
--- a/os/hal/ports/STM32/LLD/DACv1/hal_dac_lld.c
+++ b/os/hal/ports/STM32/LLD/DACv1/hal_dac_lld.c
@@ -672,7 +672,9 @@ void dac_lld_start_conversion(DACDriver *dacp) {
/* In this mode the size of the buffer is halved because two samples
packed in a single dacsample_t element.*/
- n = (n + 1) / 2;
+ /* following line commented out to avoid callback called after ^M
+ quart buffer instead half buffer */^M
+ /* n = (n + 1) / 2;*/^M
break;
#if STM32_DAC_DUAL_MODE == TRUE
case DAC_DHRM_12BIT_RIGHT_DUAL:
Fix is given just as indication since it does not take into account all the other mode (dual, or DAC with more than 2 channels)
Alexandre
