Hey,
When upgrading my working copy of ChibiOS, I noticed that my targets no longer compile.
I tracked it down to commit https://github.com/ChibiOS/ChibiOS/comm ... 176d568839, which removes file os/common/ports/ARMCMx/compilers/GCC/mk/port_v7m.mk (among others).
These files are currently in use by ChibiOS-Contrib, see e.g. https://github.com/ChibiOS/ChibiOS-Cont ... efile#L102
Would it be possible to revert the commit to keep the targets working, and find a solution that migrates the ChibiOS-Contrib code first?
Thanks!
ARMCMx removal breaks ChibiOS-Contrib targets (e.g. Teensy 3.6) Topic is solved
- Has thanked: 4 times
- Been thanked: 3 times
Re: ARMCMx removal breaks ChibiOS-Contrib targets (e.g. Teensy 3.6)
The solution is to change the port line to:
You will also need to update the chconf.h file using ChibiOS/tools/updater/update_chconf_rt.sh.
include $(CHIBIOS)/os/common/ports/ARMv7-M/compilers/GCC/mk/port.mk
- Has thanked: 21 times
- Been thanked: 30 times
Contrib repo always targets the latest stable branch, so if it's on master don't expect it to work 100%.
Please open a github issue about this, it's easier for us to track.
Users browsing this forum: No registered users and 59 guests
