Hi guys,
I believe there is an error in the macros in hal_i2s_lld.h that check whether correct DMA streams are configured in mcuconf.h.
Beginning in line 260 (/* Check on the validity of the assigned DMA channels.*/) the macro STM32_DMA_IS_VALID_ID is executed for every RX and TX channel. However, the required STM32_SPIx_RX_DMA_MSK is not defined for devices with DMAMUX peripheral, which leads to the error "invalid DMA stream associated to SPIx RX/TX".
In hal_spi_lld.h there is a differentiation between all devices (checked with STM32_DMA_IS_VALID_STREAM) and an additional check for devices without DMAMUX (line 392) with the macro STM32_DMA_IS_VALID_ID from above.
Copying the code from hal_spi_lld.h to hal_i2s_lld.h (and adjusting all occurrences of SPI to I2S) solves the problem.
Checking validity of DMA channels in I2S LLD on devices with DMAMUX peripheral Topic is solved
Re: Checking validity of DMA channels in I2S LLD on devices with DMAMUX peripheral
Thanks for finding, could you post the modified file or a patch? (zipped or the forum would reject it)
sure, see attached file. I also included a modified hal_spi_lld.h, as in line 336 only TX channel for SPI1 is checked and I think check for RX channel is missing.
As i mentioned, this is all regarding SPIv2 for STM32.
- hal_i2s_lld_fix.zip
- (5.2 KiB) Downloaded 102 times
bumping as self-reminder
Fixed bug #1229.
Fixed the missing check in the SPI driver, the I2S file was wrong, it checked SPI settings instead of I2S, it appears OK on the repository.
Fixed bug #1229.
Users browsing this forum: No registered users and 53 guests
