[INFO] EX going unstable for a while Topic is solved
Discussions and support about ChibiOS/EX, the External Peripherals Abstraction Layer.
RoccoMarco
Has thanked: 83 times
Been thanked: 67 times
Postby RoccoMarco » Mon Feb 26, 2018 11:38 pm
Hello there,
EX code will be unstable for a couple of days. We are implementing multiple interfaces to solve some known issues.
Current Status:
  • HTS221 -> Reworked on trunk, Backported to 18.2.x
  • L3GD20 -> Reworked on trunk, Backported to 18.2.x
  • LIS3DSH -> Reworked on trunk, Backported to 18.2.x
  • LIS3MDL -> Reworked on trunk, Backported to 18.2.x
  • LIS302DL -> Reworked on trunk, Backported to 18.2.x
  • LPS25H -> Reworked on trunk, Backported to 18.2.x
  • LSM6DS0 -> Reworked on trunk, Backported to 18.2.x
  • LSM303DLHC -> Reworked on trunk, Backported to 18.2.x
Ciao,
RM
faisal
Has thanked: 44 times
Been thanked: 60 times
Re: [INFO] EX going unstable for a while
Postby faisal » Sat Mar 10, 2018 2:21 am
The structure in the header files in EX are a little different from the structure in HAL.
One example is that of how the VMT is defined. In HAL you'll find this structure:
#define _something_methods   \
  _parent_methods         \
  /* do method.*/         \
  void (*do)(void *par);
struct SomethingVMT {
  _something_methods
In EX, you've implemented this structure:
#define _something_methods_alone   \
  /* do method.*/            \
  _parent_methods            \
  _something_methods
Can you make them consistent, one way or the other ?
faisal
Postby faisal » Sat Mar 10, 2018 2:27 am
Oh, while I was browsing, I noticed a minor typo in HTS221.h line 168: "Driver pre-thermoile time settings."
I'm guessing that should be "pre-compile" .
And on Line 85, I that thermo_sens looks wierd, maybe a decimal missing? It isn't used anywhere in the code ..
#define HTS221_THERMO_SENS 00015625f .
RoccoMarco
Postby RoccoMarco » Sat Mar 10, 2018 9:43 am
Thanks for reporting. Going to fix it.
I know they are not used. This because this sensor has certain internal registers which can be used to compute real sensitivity and bias. Defines represent the typical value : are there just to keep code pattern similar between all mems.
Note that ex drivers do not extend BaseSensor anymore so they could be different. An EX driver extends BaseObject and implements one ore more BaseSensor: this because most of them have to offer a multiple interface to sereveral kind of base sensors.
We could add a stub define in BaseSensors classes but it would be pointless: these classes have not specific methods.
Ciao,
RM
faisal
Postby faisal » Sun Mar 11, 2018 5:39 am
LIS3MDL doesn't seem to fit pattern of other drivers. Shouldn't it expose a BaseCompass interface? I'm seeing things done in different ways, it's making it difficult to design other drivers and interfaces to be aligned with the OO-style Chibi has adopted..
Has thanked: 1076 times
Been thanked: 922 times
Postby Giovanni » Sun Mar 11, 2018 7:44 am
There are now two ways to implement a driver:
1) Simply extending an existing class this requires no interfaces.
2) Extending a class and implementing multiple interfaces, used for devices that need to expose multiple aspects.
Are you referring to this?
RoccoMarco
Postby RoccoMarco » Sun Mar 11, 2018 1:24 pm
faisal wrote:LIS3MDL doesn't seem to fit pattern of other drivers. Shouldn't it expose a BaseCompass interface? I'm seeing things done in different ways, it's making it difficult to design other drivers and interfaces to be aligned with the OO-style Chibi has adopted..
My bad, I reworked LIS3DSH not LIS3MDL (it was late last night :lol:).
Check all the drivers which have been re-worked. Their pattern should be consistent between each other.
Ciao,
RM
RoccoMarco
Re: [INFO] EX going unstable for a while  Topic is solved
Postby RoccoMarco » Mon Mar 12, 2018 10:46 pm
Reworked and backported to 18.2.x
Ciao,
RM
faisal
Postby faisal » Mon Mar 19, 2018 7:35 pm
You shouldn't have backported EX trunk to 18.2.x stable. The 18.2.x stable branch doesn't support the latest changes to the abstract classes (hal_objects..), and are incompatible with trunk. Please revert the changes so that the EX drivers are compatible with 18.2.x stable.
RoccoMarco
Postby RoccoMarco » Mon Mar 19, 2018 10:17 pm
I have backported hal_objects and base peripherals. Update the repository.
Ciao,
RM
Return to “ChibiOS/EX”
