[INFO] lwIP version 2.0 Topic is solved
Re: [INFO] lwIP version 2.0
Merged the two threads.
Any news on this front?
I hope to have a full release sometime in February.
Marco
Has thanked: 4 times
Been thanked: 11 times
Post by Marco »
I have been quite busy last weeks (and still) so i didn't continue my work on this. I will make sure all the work so far is in the git repository. If i remember correct i started working on a PPPoE netif but didn't know how to continue.
For this upcoming release a working Ethernet and PPPoS driver should be feasible IMO. I'll try to clean it a bit so you can include it in the release.
Marco
steved
Has thanked: 12 times
Been thanked: 138 times
Post by steved »
I've updated the lwIP bindings to work with lwIP V2.0.2.
This also incorporates iggarpe's buffer patch (and a file without it)
Basic testing with the web server is fine
Using the 17.6.0 release
lwip_2.02-patched.7z
Patched version of lwIP 2.0.2 for ChibiOS
(2.78 MiB) Downloaded 562 times
lwip_bindings.7z
ChibiOS to lwIP bindings for Chibi 17.6/lwIP 2.0.2
(26.33 KiB) Downloaded 557 times
Thanks, I will try to integrate before next release.
steved
Post by steved »
As an addendum, I'm sure I've seen a post on this (duplicate definition of struct timeval), but can't find it. From lwip's sockets.h:
/** LWIP_TIMEVAL_PRIVATE: if you want to use the struct timeval provided
 * by your system, set this to 0 and include <sys/time.h> in cc.h */
(Applies to both 1.4 and 2.0)
My inclination would be to set LWIP_TIMEVAL_PRIVATE to zero and do the include in Chibi's cc.h; in an ideal world I can see no need to override a standard definition. However the non-GCC world may be less than ideal; might this need to be a project-configurable option?
At very least there could be an #ifndef around the definition so it can be set in prjects options.
steved
Post by steved »
Giovanni wrote:At very least there could be an #ifndef around the definition so it can be set in prjects options.
Works better than expected - looks like the include order gets the message through OK (which I didn't expect on a cursory glance).
lwip_bindings.7z
lwip Chibi bindings with option to use standard definition of struct timeval
(26.41 KiB) Downloaded 532 times
steved
Post by steved »
I've updated the bindings to address bug #729 - all works fine on a quick check (although also worked fine before).
Bug #824 was addressed in the previous upload.
lwip_bindings.zip
lwIP bindings latest
(43.46 KiB) Downloaded 524 times
Do demos require adjustments after implementing this change?
