ESP32
ChibiOS public support forum for topics related to the Espressif ESP32 family of micro-controllers.
Has thanked: 836 times
Been thanked: 730 times
Re: ESP32
Postby Giovanni » Wed Nov 14, 2018 2:46 pm
There is not much moderation to do as I wrote, surprisingly enough in 10 years this forum never needed serious moderation.
Up to you to organize this effort. moderators are just names put up there.
Marco
Has thanked: 4 times
Been thanked: 11 times
Re: ESP32
Postby Marco » Wed Nov 14, 2018 7:26 pm
Giovanni wrote:I just created the forum (icon missing), moving this topic there.
Anybody volunteering as moderator? not much to do anyway, usually I cut problems "at the root".
I can do it if needed, i don’t mind. :)
Marco
davidbuzz
Re: ESP32
Postby davidbuzz » Thu Nov 15, 2018 12:19 am
This doc provides more in depth info on the cpu,memory,peripherals,interupt matrix,clocks, up, and all the on-board peripheral controllers... I think it's getting close to what u wanted...?
https://espressif.com/sites/default/fil ... ual_en.pdf
davidbuzz
Re: ESP32
Postby davidbuzz » Thu Nov 15, 2018 12:28 am
Ok, I think I found the right reference ...
https://0x04.net/~mwk/doc/xtensa.pdf
"Xtensa® Instruction Set Architecture (ISA) Reference Manual For All Xtensa Processor Cores"
Re: ESP32
Postby Giovanni » Thu Nov 15, 2018 7:25 am
Some relevant points I got from that document:
1) There is no dual stack like Cortex-M but it has a dedicated bit PS.UM that can be used for SW stack switching.
2) There is a stack overflow/underflow protection that is very useful.
3) EPC and PS should be part of port_extctx.
4) Very few registers (a12 – a15) are callee-saved so part of port_intctx, this means that switching from thread to thread is going to be very fast.
5) The xtensa has a lot of option, we need to target a specific implementation or set of options.
davidbuzz
Re: ESP32
Postby davidbuzz » Thu Nov 15, 2018 1:20 pm
Regarding the 'options, we are targeting what is known as the 'esp32' 'SOC', so it's certainly a very specific single silicon, that is a dual core Tensilica Xtensa LX6 running at 240mhz, and the Wikipedia page says it's 520 KiB SRAM and the identifier of the chip is ESP32-D0WDQ6 and typically has 4MiB of external flash attached.
References:
https://en.m.wikipedia.org/wiki/ESP32
davidbuzz
Re: ESP32
Postby davidbuzz » Thu Nov 15, 2018 1:36 pm
Here is the definitive list from espressif of what core options are included in the esp32, and what are not.... and other goodies...
https://github.com/espressif/esp-idf/bl ... core-isa.h
davidbuzz
Re: ESP32
Postby davidbuzz » Thu Nov 15, 2018 1:39 pm
Configuration overlay can be found here...
https://github.com/jcmvbkbc/crosstool-N ... _esp32.tar
davidbuzz
Re: ESP32
Postby davidbuzz » Thu Nov 15, 2018 1:46 pm
I also just discovered that the Zephyr OS , another embedded rtos, also runs on the esp32, so just worth mentioning.. .
Reference:
https://docs.zephyrproject.org/latest/i ... ephyr.html
https://docs.zephyrproject.org/latest/b ... esp32.html
davidbuzz
Re: ESP32
Postby davidbuzz » Thu Nov 15, 2018 2:01 pm
ABI and overlay and calling conventions discussed and linked here: https://www.esp32.com/viewtopic.php?t=4227
Return to “ESP32 Support”
