Howto: CLion and ChibiOS
JSStabl
Postby JSStabl » Mon Mar 02, 2020 3:56 pm
Since CLion supports OpenOCD it's rather easy to use with ChibiOS. I'm using WSL for the compiler. CLion only accepts CMake Projects as of now, so I'm using a CMake Macro and a compileDB to get Clion to work.
Simply add a CMakeLists.txt to the directory. Setup WSL as a compiler (or mingw, cygwin). And then add a OpenOCD Launch Configuration pointing to the elf file. Debugging works too, it doesn't have the stack analyzer that ChibiStudio supports but I like having a modern IDE more :)
Content of the CMakeLists.txt:
cmake_minimum_required(VERSION 3.5 FATAL_ERROR)
project( VERSION )
macro (add_target name)
    set(default_opt BUILD_DIR=${CMAKE_BINARY_DIR}/${name})
    add_custom_target(${name}
            WORKING_DIRECTORY ${PROJECT_SOURCE_DIR}
            COMMAND rm -rf compile_commands.json
            COMMAND /home/julian/.local/bin/compiledb -n make ${default_opt} ${ARGN}
            COMMAND make ${default_opt} ${ARGN})
endmacro()
add_target(masterf7)
rastro
Re: Howto: CLion and ChibiOS
Postby rastro » Thu May 14, 2020 9:27 pm
Same time ago I found this: https://github.com/ObKo/stm32-cmake . In general it's cmake toolchain for STM32, but also support chibios.
So, jetbrains still promise to add support to the makefile. However I lost hope.
JSStabl
Postby JSStabl » Fri May 15, 2020 8:55 am
I'm in contact with them. They promised to have a beta some time this year :)
Interesting project, not entirely sure how that works yet, since chibiOS is makefile based :)
Has thanked: 785 times
Been thanked: 679 times
Postby Giovanni » Fri May 15, 2020 9:01 am
ChibiOS can be compiled with anything, we just use make for convenience, it is always available and well understood.
JSStabl
Postby JSStabl » Fri May 15, 2020 10:24 am
Yes of course, but all the submodules conviently provide .mk files that can simply be included from the master Makefile. If I use CMake I have to rewrite those or finde some other ways to only compile the needed modules.
Return to “User Projects”
