Required materials
ESP32
KOB electronic lock
Relay
STONE STWI070WT-01 touch panel display
MFRC522 module
Realized function
1. card registration.
2. username and password registration.
3. card swipe to unlock the electronic lock.
4. User name and password to unlock the electronic lock.
Connection diagram
GUI design
Intelligent access control based on ESP32 and TFT LCD
Re: Intelligent access control based on ESP32 and TFT LCD
code sharing
Video demo
https://www.youtube.com/watch?v=Gl-Nofxb6I4
import mfrc522
import time
import _thread
from os import uname
from machine import Pin, UART
#from pyb import UART
#import machine
suos = Pin(32,Pin.OUT)
uart2 = UART(2, baudrate=115200, rx=16,tx=17,timeout=10)
ESP32_HSPI_CLOCK = 14
ESP32_HSPI_SLAVE_SELECT = 15
ESP32_HSPI_MISO = 12
ESP32_HSPI_MOSI = 13
ESP32_MFRC522_RST = 5
rx3 = []
rx_name = []
user_id_flag = False
password_flag = False
temp_id = ''
temp_mima = ''
personnel_id = {'zbw':[236,230,169,47],'lbw':[19,165,93,4]}
personnel_ps = {'zbw':'zbw3366','lbw':'lbwnb'}
admin_password = ('yyds')
button_cmd = [16,1]
edit1_cmd = [16,112]
edit2_cmd = [16,113]
edit3_cmd = [16,114]
if uname()[0] == 'esp32':
rdr = mfrc522.MFRC522(ESP32_HSPI_CLOCK, ESP32_HSPI_MOSI, ESP32_HSPI_MISO, ESP32_MFRC522_RST, ESP32_HSPI_SLAVE_SELECT)
def do_write():
try:
(stat, tag_type) = rdr.request(rdr.REQIDL)
if stat == rdr.OK:
(stat, raw_uid) = rdr.anticoll()
if stat == rdr.OK:
print("New card detected")
print(" - tag type: 0x%02x" % tag_type)
print(" - uid : 0x%02x%02x%02x%02x" % (raw_uid[0], raw_uid[1], raw_uid[2], raw_uid[3]))
print("")
if rdr.select_tag(raw_uid) == rdr.OK:
key = [0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF]
if rdr.auth(rdr.AUTHENT1A, 8, key, raw_uid) == rdr.OK:
stat = rdr.write(8, b"\x00\x53\x00\x54\x00\x4F\x00\x4E\x00\x45\x0a\x0b\x0c\x0d\x0e\x0f")
rdr.stop_crypto1()
if stat == rdr.OK:
print("Data written to card")
else:
print("Failed to write data to card")
else:
print("Authentication error")
else:
print("Failed to select tag")
except KeyboardInterrupt:
print("write error")
def do_read():
while True:
try:
if stat == rdr.OK:
if stat == rdr.OK:
print (raw_uid[0], raw_uid[1], raw_uid[2], raw_uid[3])
print("")
print("Address 8 data: %s" % rdr.read(8))
for ps in personnel_id:
if raw_uid[0:4:1] == personnel_id.get(ps):
suos.value(1)
print(ps)
uart_write(ps, *raw_uid[0:4:1])
time.sleep(3)
uart2.sendbreak()
break
rdr.stop_crypto1()
time.sleep(3)
suos.value(0)
else:
else:
if uart2.any()>1:
rx2 = []
data_name2 = ''
bin_data = uart2.read(40)
uart2.sendbreak()
rx1 = list(bin_data)
for item in rx1:
rx2.append(chr(item))
print(rx2)
if rx1[3:5:1] == button_cmd:
data_name_len = rx1[6] - 1
data_name = rx2[7:data_name_len+7:1]
data_name2 = ''.join(data_name)
print(data_name2)
if data_name2 == 'back3':
return
print("read error")
def do_read2 (idd):
print(idd)
while True:
try:
if stat == rdr.OK:
if stat == rdr.OK:
print("")
personnel_id[idd] = raw_uid[0:4:1]
uart_write3(*raw_uid[0:4:1])
rdr.stop_crypto1()
else:
else:
if uart2.any()>1:
rx2 = []
data_name2 = ''
uart2.sendbreak()
for item in rx1:
print(data_name2)
if data_name2 == 'back1':
return
print("read error")
def uart_write(text, *ids):
# print(text, *ids)
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardname1","text":"'+str(text)+'"}>ET')
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid1","text":"'+str(ids)+'"}>ET')
uart2.write('ST<{"cmd_code":"set_visible","type":"widget","widget":"lock1","visible":true}>ET')
time.sleep(3)
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardname1","text":"''"}>ET')
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid1","text":"''"}>ET')
uart2.write('ST<{"cmd_code":"set_visible","type":"widget","widget":"lock1","visible":false}>ET')
def uart_write2(text,text2):
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid","text":"'+text+'"}>ET')
time.sleep(3)
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid","text":"'+text2+'"}>ET')
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit2","text":"''"}>ET')
def uart_write3(*id2):
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid","text":"'+str(id2)+'"}>ET')
time.sleep(3)
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid","text":"''"}>ET')
def uart_write4(text,text2):
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"login","text":"'+text+'"}>ET')
time.sleep(1)
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"login","text":"'+text2+'"}>ET')
time.sleep(1)
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit3","text":"''"}>ET')
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit4","text":"''"}>ET')
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit7","text":"''"}>ET')
def uart_write5():
time.sleep(3)
def card_zhuce():
while True:
if uart2.any():
user_id = ''
password = ''
rx2 = []
rx_num = 0
uart2.sendbreak()
for item in rx1:
rx_num += 1
data_end = rx_num-5
data_id_st = rx2[8:13:1]
data_id_st2 = ''.join(data_id_st)
print(data_id_st2)
if data_id_st2 == 'edit1':
data_id_st3 = rx2[15:data_end:1]
data_id_st4 = ''.join(data_id_st3)
print(data_id_st4)
if data_id_st4 != '':
name = True
elif data_id_st2 == 'edit2':
data_id_st5 = rx2[15:data_end:1]
data_id_st6 = ''.join(data_id_st5)
if data_id_st6 == admin_password:
admin = True
uart_write2('Verification passed!','Please place the card!')
do_read2(data_id_st4)
return
def mima_zuce():
temp_id3 = ''
temp_mima3 = ''
while True:
if uart2.any():
user_id = ''
password = ''
rx2 = []
rx_num = 0
# data_end = 0
uart2.sendbreak()
for item in rx1:
rx_num += 1
# if (rx2[rx_num] == 'T') and (rx2[rx_num-1] == 'E') and (rx2[rx_num-2] == '>'):
# break
data_end = rx_num-5
print(data_id_st2)
print(data_name2)
if data_name2 == 'back2':
return
if data_id_st2 == 'edit3':
print(data_id_st4)
user_id_flag = True
temp_id3 = data_id_st4
# personnel_ps[temp_id] = raw_uid[0:4:1]
elif data_id_st2 == 'edit4':
print(data_id_st6)
# if personnel_ps.get(temp_id) == data_id_st6:
password_flag = True
temp_mima3 = data_id_st6
# personnel_ps[temp_id] = password_flag
# print(rx2,user_id_flag,password_flag)
elif data_id_st2 == 'edit7':
if (data_id_st6 == admin_password) and (password_flag == True) and (user_id_flag == True):
admin = True
personnel_ps[temp_id3] = temp_mima3
uart_write4('Verification passed!','login was successful!')
def password_loin():
temp_id2 = ''
temp_mima = ''
while True:
if uart2.any():
user_id = ''
password = ''
rx2 = []
rx_num = 0
# data_end = 0
uart2.sendbreak()
for item in rx1:
rx_num += 1
# break
data_end = rx_num-5
print(data_id_st2)
print(data_name2)
if data_name2 == 'back4':
return
if data_id_st2 == 'edit5':
print(data_id_st4)
if data_id_st4 in personnel_ps:
user_id_flag = True
temp_id2 = data_id_st4
elif data_id_st2 == 'edit6':
print(data_id_st6)
print(temp_id2)
print(personnel_ps)
if personnel_ps.get(temp_id2) == data_id_st6:
print(user_id_flag,password_flag)
if (password_flag == True) and (user_id_flag == True):
uart_write(temp_id2,temp_id2)
suos.value(1)
uart2.write('ST<{"cmd_code":"set_visible","type":"widget","widget":"lock2","visible":true}>ET')
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit5","text":"''"}>ET')
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit6","text":"''"}>ET')
time.sleep(3)
# uart_write('student','')
suos.value(0)
uart2.write('ST<{"cmd_code":"set_visible","type":"widget","widget":"lock2","visible":false}>ET')
uart2.sendbreak()
while True:
if uart2.any()>1:
rx2 = []
data_name2 = ''
# time.sleep(1)
uart2.sendbreak()
# time.sleep(1)
for item in rx1:
print(rx2)
print(data_name2)
if data_name2 == 'card1':
card_zhuce()
elif data_name2 == 'password1':
mima_zuce()
elif data_name2 == 'card2':
do_read()
elif data_name2 == 'password2':
password_loin()
Video demo
