Direct LCD Drive
Re: Direct LCD Drive
What do you mean by this driver? If you provide a driver to the GDISP module which is able to handle setPixel() calls, then you can use it without any problems.
See this application note from ST, basically directly driviny a TFT without a controller chip.
http://www.st.com/st-web-ui/static/acti ... 278141.pdf
ChibiOS/GFX does not care about how you write to the display. If you can provide a driver which does handle this function call, it will work:
What you'd have to do is simply manipulate the registers inside the STM32 to drive the direct LCD drive peripheral, instead of sending some SPI commands to an external controller like other drivers do.
TL;DR -> yes, it will work.
void gdisp_lld_draw_pixel(coord_t x, coord_t y, color_t color);
- Has thanked: 19 times
- Been thanked: 24 times
To drive a TFT panel directly, you have to generate 3 clocks: VSYNC, HSYNC and the pixel clock. Also you need a parrallel port to write the data.
You'd have to write a driver to work with STM32 as you will have to use the timers and DMA controller.
As long as you have an FSMC and some SRAM it's possible.
Also the new F4x9 devices have an integrated TFT driver and DDR controller, it would be much easier/cheaper to make it work and performance would be best.
To write data to the screen you just need to write to the frame buffer.
mobyfab wrote:To drive a TFT panel directly, you have to generate 3 clocks: VSYNC, HSYNC and the pixel clock. Also you need a parrallel port to write the data.
As per my post link to STM Appnote on Direct Driving
PS F4x9 devices are not currently available, they are not released to mass market. Also this will not be the cheapest solution, i dont need 180Mhz with DSP.
Tectu wrote:ChibiOS/GFX does not care about how you write to the display. If you can provide a driver which does handle this function call, it will work:Code: Select all
Mmmmm as the direct drive implementation DMA's display buffer from SRAM to the Display, all that should be needed is to get
writing to the correct SRAM locations. Could be very simple this
