i want to use the exti line to start an adc conversion.
are there any example about this topic?
any suggestion will be apprectiated
giancarlo
STM32f3Discovery : ADC conversion triggered by an EXTI line
Re: STM32f3Discovery : ADC conversion triggered by an EXTI l
I don't have an example but it is very simple, just call adcStartConversionI() from the EXT callback, the conversion end is signaled by the ADC callback.
Remember that you have to put "I" APIs within chSysLockFromIsr() and chSysUnlockFromIsr().
hi giovanni,
this is my code, after you suggestion but i'm not lucky....
and the adc conversiongoup is
....what's wrog with it?
thanks
giancarlo
static void extcb1(EXTDriver *extp, expchannel_t channel) {
static VirtualTimer vt4;
(void)extp;
(void)channel;
chSysLockFromIsr();
if (chVTIsArmedI(&vt4))
chVTResetI(&vt4);
adcStartConversionI(&ADCD1, &adcgrpcfg1, samples1, ADC_GRP1_BUF_DEPTH);
/* Disattiva il Sample dopo 200mS del trigger*/
chVTSetI(&vt4, MS2ST(200), AttivaSampleHold, NULL);
chSysUnlockFromIsr();
}and the adc conversiongoup is
* ADC conversion group.
* Mode: Linear buffer, 8 samples of 2 channels, SW triggered.
* Channels: IN7 = PC1, IN8 = PC2.
* IN5 = PF4 -----------CASO RAMONA INPUT ADC!!!!!!
static const ADCConversionGroup adcgrpcfg1 = {
FALSE,
ADC_GRP1_NUM_CHANNELS,
adccallback,
adcerrorcallback,
0, /* CFGR */
ADC_TR(0, 4095), /* TR1 */
0, /* CCR */
{ /* SMPR[2] */
0,
0
{ /* SQR[4] */
ADC_SQR1_SQ1_N(ADC_CHANNEL_IN5) | ADC_SQR1_SQ2_N(ADC_CHANNEL_IN8),
0,
0,
0
};....what's wrog with it?
thanks
giancarlo
have i to configure the ADC_CFGR registers?
thanks
giancarlo
thanks
giancarlo
The code looks correct, probably it is a problem with the conversion group structure, look at the F4 ADC example under ./testhal.
It would be useful to specify what you expect from the code and what you get instead.
hi,
I would like to control the ADC via an external trigger, which in my case is a rising edge on a pin.
I checked the pin setting is correct for both the adc and the trigger.
I took the examples in testhal (EXTI and ADC) and work. Now I would like to combine the two.
It happens that the code is locked after the first time i triggered...so i cannot perform anything
thanks for your patience
greetings
giancarlo
the main.c code is :
greetings
giancarlo
include "ch.h"
#define ADC_GRP1_NUM_CHANNELS 2
#define ADC_GRP1_BUF_DEPTH 16
static adcsample_t samples1[ADC_GRP1_NUM_CHANNELS * ADC_GRP1_BUF_DEPTH];
float sample;
float ADCConversionValue;
* ADC streaming callback.
size_t nx = 0, ny = 0;
static void adccallback(ADCDriver *adcp, adcsample_t *buffer, size_t n) {
(void)adcp;
if (samples1 == buffer) {
nx += n;
else {
ny += n;
static void adcerrorcallback(ADCDriver *adcp, adcerror_t err) {
(void)adcp;
(void)err;
* Mode: Linear buffer, 16 samples of 2 channels, SW triggered.
* IN5 = PF4
FALSE,
NULL,
adcerrorcallback,
0, /* CFGR */
0, /* CCR */
{ /* SMPR[2] */
0,
0
{ /* SQR[4] */
0,
0,
0
static void AttivaSampleHold(void *arg) {
(void)arg;
palTogglePad(GPIOE, GPIOE_LED8_ORANGE);
palTogglePad(GPIOE, GPIOE_LED5_ORANGE);
/* Trigger ADC */
(void)extp;
(void)channel;
chSysLockFromIsr();
chVTResetI(&vt4);
static void led4off(void *arg) {
(void)arg;
palClearPad(GPIOE, GPIOE_LED4_BLUE);
/* Triggered when the button is pressed or released. The LED5 is set to ON.*/
static void extcb2(EXTDriver *extp, expchannel_t channel) {
(void)extp;
(void)channel;
palSetPad(GPIOE, GPIOE_LED4_BLUE);
chSysLockFromIsr();
chVTResetI(&vt4);
/* LED4 set to OFF after 200mS.*/
chVTSetI(&vt4, MS2ST(200), led4off, NULL);
* EXT CONFIGURAZIONE PAD
{EXT_CH_MODE_BOTH_EDGES | EXT_CH_MODE_AUTOSTART | EXT_MODE_GPIOA, extcb2},
{EXT_CH_MODE_DISABLED, NULL},
{EXT_CH_MODE_RISING_EDGE | EXT_CH_MODE_AUTOSTART | EXT_MODE_GPIOE, extcb1},
void padInit(void){
palSetPadMode(GPIOE,GPIOE_PIN6,PAL_MODE_INPUT);
palSetPadMode(GPIOF,GPIOF_PIN4,PAL_MODE_INPUT_ANALOG);
* Application entry point.
int main(void) {
* System initializations.
* and performs the board-specific initializations.
* RTOS is active.
* Inizializzazione PIN
padInit();
* PE6 TRIGGER ANALOGICO INPUT INTERRUPT USCITA COMPARATORE
* PF4 ---ANALOG INPUT
* PC2 ---GROUND
palSetPad(GPIOE, GPIOE_LED5_ORANGE);
palSetPad(GPIOE, GPIOE_LED8_ORANGE);
extStart(&EXTD1, &extcfg);
ADCConversionValue = (3.3 / 4095);
while (TRUE) {
extChannelEnable(&EXTD1, 0);
palSetPad(GPIOE, GPIOE_LED7_GREEN);
chThdSleepMilliseconds(100);
palClearPad(GPIOE, GPIOE_LED7_GREEN);
//ACCENSIONE E SPEGNIMENTO LED 4 di Colore BLU
palSetPad(GPIOE, GPIOE_LED9_BLUE);
chThdSleepMilliseconds(200);
palClearPad(GPIOE, GPIOE_LED9_BLUE);
return 0;
Posting code does not help much.
You need to:
1) enable the debug options in chconf.h
2) after the program stops see the stack trace using the debuger
3) if it stops in port_stop() then read the message pointed by dbg_panic_msg
You need to:
