TM-Subsystem / SD-Card / STM32F0 / unknown type name 'halrtc
Ramazzukk
Postby Ramazzukk » Sat May 03, 2014 6:41 am
Hi there,
I am trying to use a SD-Card / FatFS with the STM32F0-Discovery-Board. Since there is no demo, I copied the relevant Code from the F107 Olimex demo. Part of the code is working (I can read at least the filenames from the card), but I don't understand the usage of the TM subsystem.
If I activate the TM subsystem at halconf (like it is in the F107-demo), the compiler gives me an error: unknown type name 'halrtcnt_t'. I compared the makefiles and conffiles an can not figure out what i'm missing.
I guess the TM subsystem is needed for this:
static void tmrfunc(void *p) {
  BaseBlockDevice *bbdp = p;
  chSysLockFromIsr()
  if (cnt > 0) {
    if (blkIsInserted(bbdp)) {
      if (--cnt == 0) {
        chEvtBroadcastI(&inserted_event);
    else
      cnt = POLLING_INTERVAL;
  else {
    if (!blkIsInserted(bbdp)) {
      chEvtBroadcastI(&removed_event);
  chVTSetI(&tmr, MS2ST(POLLING_DELAY), tmrfunc, bbdp);
  chSysUnlockFromIsr();
Do I have to switch on another part (mcuconf or somewhere)? Any guidance is greatly appreciated beforehand!
Has thanked: 1179 times
Been thanked: 979 times
Re: TM-Subsystem / SD-Card / STM32F0 / unknown type name 'ha
Postby Giovanni » Sat May 03, 2014 8:16 am
The TM subsystem is not supported on the M0 CPUs because they lack the RT counter register.
Anyway, it is not needed in your case, that code uses virtual timers which are unrelated to TM.
Ramazzukk
Postby Ramazzukk » Sat May 03, 2014 10:52 am
Hi Giovanni
Thank you very much for your quick response!
Ramazzukk
Postby Ramazzukk » Sun May 04, 2014 5:04 pm
Hi there again,
Maybe its very simple, but im struggling to understand following section:
  chSysLockFromIsr();
  if (cnt > 0) {
      if (--cnt == 0) {
    else
  else {
In IOBlock.h is
#define blkIsInserted(ip) ((ip)->vmt->is_inserted(ip)).
Then Eclipse points me to three different directions: ioblock.h, mmc_spi.h, mmcsd.h..
How ist blkIsInserted(bbdp) becoming true? I can't figure out..
Thank you for any further guidance..
Postby Giovanni » Sun May 04, 2014 6:01 pm
That macro ultimately calls a function in board.c, the detection method for cards is board-dependent. you need to make sure that your board.c implements that function.
Ramazzukk
Postby Ramazzukk » Sun May 04, 2014 7:45 pm
Thank you for your reply. I've found it now:
#if HAL_USE_MMC_SPI || defined(__DOXYGEN__)
 * @brief   MMC_SPI card detection.
bool_t mmc_lld_is_card_inserted(MMCDriver *mmcp) {
  (void)mmcp;
  /* TODO: Fill the implementation.*/
  return TRUE;
Postby Giovanni » Sun May 04, 2014 8:08 pm
Yes, that one.
Return to “STM32 Support”
Users browsing this forum: No registered users and 29 guests
