Just FYI, I have preliminary code working now....
*** ChibiOS/RT test suite
*** Kernel: 3.0.0
*** Compiled: Aug 3 2015 - 15:30:46
*** Compiler: GCC 4.7.4 20140401 (release) [ARM/embedded-4_7-branch revision 209195]
*** Architecture: ARMv7E-M
*** Core Variant: Cortex-M7
*** Port Info: Advanced kernel mode
*** Platform: STM32F746 Very High Performance with DSP and FPU
*** Test Board: STMicroelectronics STM32F746G-Discovery
--- Test Case 1.1 (System, critical zones)
--- Result: SUCCESS
--- Test Case 1.2 (System, interrupts handling)
--- Result: SUCCESS
--- Test Case 1.3 (System, integrity)
--- Result: SUCCESS
--- Test Case 2.1 (Threads, enqueuing test #1)
--- Result: SUCCESS
--- Test Case 2.2 (Threads, enqueuing test #2)
--- Result: SUCCESS
--- Test Case 2.3 (Threads, priority change)
--- Result: SUCCESS
--- Test Case 2.4 (Threads, delays)
--- Result: SUCCESS
--- Test Case 3.1 (Semaphores, enqueuing)
--- Result: SUCCESS
--- Test Case 3.2 (Semaphores, timeout)
--- Result: SUCCESS
--- Test Case 3.3 (Semaphores, atomic signal-wait)
--- Result: SUCCESS
--- Test Case 3.4 (Binary Semaphores, functionality)
--- Result: SUCCESS
--- Test Case 4.1 (Mutexes, priority enqueuing test)
--- Result: SUCCESS
--- Test Case 4.2 (Mutexes, priority return)
--- Result: SUCCESS
--- Test Case 4.3 (Mutexes, status)
--- Result: SUCCESS
--- Test Case 4.4 (CondVar, signal test)
--- Result: SUCCESS
--- Test Case 4.5 (CondVar, broadcast test)
--- Result: SUCCESS
--- Test Case 4.6 (CondVar, boost test)
--- Result: SUCCESS
--- Test Case 5.1 (Messages, loop)
--- Result: SUCCESS
--- Test Case 6.1 (Mailboxes, queuing and timeouts)
--- Result: SUCCESS
--- Test Case 7.1 (Events, registration and dispatch)
--- Result: SUCCESS
--- Test Case 7.2 (Events, wait and broadcast)
--- Result: SUCCESS
--- Test Case 7.3 (Events, timeouts)
--- Result: SUCCESS
--- Test Case 8.1 (Heap, allocation and fragmentation test)
--- Result: SUCCESS
--- Test Case 9.1 (Memory Pools, queue/dequeue)
--- Result: SUCCESS
--- Test Case 10.1 (Dynamic APIs, threads creation from heap)
--- Result: SUCCESS
--- Test Case 10.2 (Dynamic APIs, threads creation from memory pool)
--- Result: SUCCESS
--- Test Case 10.3 (Dynamic APIs, registry and references)
--- Result: SUCCESS
--- Test Case 11.1 (Queues, input queues)
--- Result: SUCCESS
--- Test Case 11.2 (Queues, output queues)
--- Result: SUCCESS
--- Test Case 12.1 (Benchmark, messages #1)
--- Score : 1145926 msgs/S, 2291852 ctxswc/S
--- Result: SUCCESS
--- Test Case 12.2 (Benchmark, messages #2)
--- Score : 886360 msgs/S, 1772720 ctxswc/S
--- Result: SUCCESS
--- Test Case 12.3 (Benchmark, messages #3)
--- Score : 747815 msgs/S, 1495630 ctxswc/S
--- Result: SUCCESS
--- Test Case 12.4 (Benchmark, context switch)
--- Score : 4592984 ctxswc/S
--- Result: SUCCESS
--- Test Case 12.5 (Benchmark, threads, full cycle)
--- Score : 633882 threads/S
--- Result: SUCCESS
--- Test Case 12.6 (Benchmark, threads, create only)
--- Score : 1112681 threads/S
--- Result: SUCCESS
--- Test Case 12.7 (Benchmark, mass reschedule, 5 threads)
--- Score : 334679 reschedules/S, 2008074 ctxswc/S
--- Result: SUCCESS
--- Test Case 12.8 (Benchmark, round robin context switching)
--- Score : 2468520 ctxswc/S
--- Result: SUCCESS
--- Test Case 12.9 (Benchmark, I/O Queues throughput)
--- Score : 3488828 bytes/S
--- Result: SUCCESS
--- Test Case 12.10 (Benchmark, virtual timers set/reset)
--- Score : 3397730 timers/S
--- Result: SUCCESS
--- Test Case 12.11 (Benchmark, semaphores wait/signal)
--- Score : 2399808 wait+signal/S
--- Result: SUCCESS
--- Test Case 12.12 (Benchmark, mutexes lock/unlock)
--- Score : 2949572 lock+unlock/S
--- Result: SUCCESS
--- Test Case 12.13 (Benchmark, RAM footprint)
--- System: 336 bytes
--- Thread: 68 bytes
--- Timer : 20 bytes
--- Semaph: 12 bytes
--- EventS: 4 bytes
--- EventL: 20 bytes
--- Mutex : 16 bytes
--- CondV.: 8 bytes
--- Queue : 36 bytes
--- MailB.: 40 bytes
--- Result: SUCCESS
Final result: SUCCESS
Compare with F4...
*** Kernel: 3.0.0p3
*** Compiled: Apr 13 2015 - 14:21:33
*** Architecture: ARMv7-ME
*** Core Variant: Cortex-M4
*** Platform: STM32F407 High Performance with DSP and FPU
*** Test Board: STMicroelectronics STM32F4-Discovery
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Score : 799993 msgs/S, 1599986 ctxswc/S
--- Result: SUCCESS
--- Score : 648644 msgs/S, 1297288 ctxswc/S
--- Result: SUCCESS
--- Result: SUCCESS
--- Score : 2559992 ctxswc/S
--- Result: SUCCESS
--- Score : 471906 threads/S
--- Result: SUCCESS
--- Score : 699995 threads/S
--- Result: SUCCESS
--- Score : 208178 reschedules/S, 1249068 ctxswc/S
--- Result: SUCCESS
--- Score : 1581160 ctxswc/S
--- Result: SUCCESS
--- Score : 1873164 bytes/S
--- Result: SUCCESS
--- Score : 1366044 timers/S
--- Result: SUCCESS
--- Score : 3199988 wait+signal/S
--- Result: SUCCESS
--- Score : 1856348 lock+unlock/S
--- Result: SUCCESS
--- EventS: 4 bytes
--- CondV.: 8 bytes
--- Result: SUCCESS
Context switch in 217nS vs 390nS.
The difference in performance is well above the mere difference in frequency (216 vs 168 MHz).
On the other hand the results fluctuate, even 1% differences in each runs while the F4 is clock-cycle accurate, effect of the deeper pipeline and I/D caches I think. With caches disabled it appears to be slower than the F4 (strange because it should still have the ART). Anyway, probably it is early silicon.
