In the feature description of Nil it is said that tasks only take 7-24 Bytes of memory http://chibios.org/dokuwiki/doku.php?id ... l:features.
Out of curiosity I have compiled the NIL-ARMCM0-GENERIC example in demos/various/ and set the WA-size to 128 Bytes for thread1 and 256 Bytes for thread2. If I look into the .dmp file, I can see that waThread1 is 0x108 (=264) Bytes and waThread2 is 0x188 (=392) Bytes, which means, that the overhead in each work area is 136 Bytes. Obviously additional 136 Bytes are not the end of the world but I'm just curious because it was stated otherwise on the website. Does anybody know what the additional 136 Bytes are good for?
BTW: I have not touched the source of the example otherwise, including chconf.h. That means all OS-features except mutexes are enabled.
Overhead of Thread Working Area in NIL and RT Topic is solved
Re: Overhead of Thread Working Area in NIL and RT
This is the expansion of the macro:
static THD_WORKING_AREA(waThread2, 128);
Those two structure represent the CPU registers that are saved into the thread stack during context switching, the 64 is the configurable option PORT_INT_REQUIRED_STACK, the rest is stack alignment.
PORT_INT_REQUIRED_STACK is set safely to 64 bytes but it can be reduced a lot, it represents the stack space used for context switch after IRQ servicing. It is set to a large value because this size can change depending on compiler version and options. It is the stack frame size of the function chSchDoReschedule() which is 8 bytes using GCC 5.4 and -O2. It can be trimmed down a lot but in general better do this after development.
stkalign_t waThread2[((size_t)((size_t)((sizeof (struct port_intctx) + \
sizeof (struct port_extctx) + \
((size_t)(128)) + ((size_t)(64)))) + \
((size_t)(sizeof (stkalign_t)) - 1U)) & ~((size_t)((sizeof (stkalign_t))) - 1U)) / sizeof (stkalign_t)]Those two structure represent the CPU registers that are saved into the thread stack during context switching, the 64 is the configurable option PORT_INT_REQUIRED_STACK, the rest is stack alignment.
Hello Giovanni,
thank you for your explanation. Now that totally makes sense to me. Probably I just should have looked at the macro expansion myself but anyway your explanation was really helpful, especially regarding the size of PORT_INT_REQUIRED_STACK. It is also good to know that the size for saving the registers during context switching is already accomodated for, so if I am not mistaken, the user-defined size of a working area is what the application itself can really use.
