Any hint about using WireShark under Linux?
Has thanked: 811 times
Been thanked: 710 times
Postby Giovanni » Mon Aug 21, 2017 5:02 pm
I am installing it on Mint using the SW manager, I am getting permission errors when trying to select usbmon.
Can anybody help?
utzig
Been thanked: 19 times
Re: Any hint about using WireShark under Linux?
Postby utzig » Mon Aug 21, 2017 5:55 pm
Hi, I use Arch Linux and there were some permission errors on files/dirs to get wireshark running for a non-priviledged user:
/sys/kernel/debug was not accessible, fix:
$ sudo chmod 755 /sys/kernel/debug
/usr/bin/dumpcap which used by wireshark was also not able to run as non-root, fix:
$ sudo chmod 755 /usr/bin/dumcap
Also you have to be sure to load usbmon:
$ sudo modprobe usbmon
That's what got everything working for me. If none of those fix the problem, try running as root (sudo wireshark) to be sure it works.
DeusExMachina
Has thanked: 3 times
Postby DeusExMachina » Tue Aug 22, 2017 8:31 am
also you may try running WireShark under root
sudo wireshark
ugly, but for the casual usage it is fine
Postby Giovanni » Tue Aug 22, 2017 8:36 am
Thanks both,
I had to assign the group wireshark to my user and change permissions on the USB pipes under usbmon but now it is working without having to work as root.
It is good at decoding protocols but apparently it is not able to give details about the setup phase. I need to find a cheap USB analyzer for that.
