Small update about MFS, I added a "transactional mode".
Basically it allows to encapsulate multiple operations (write, erase, read) in a transaction then commit all of those atomically or roll-back everything.
If there is a power loss the whole transaction is undone on the next boot.
Now we need more flash drivers.
[NEWS] Introducing MFS
- Has thanked: 787 times
- Been thanked: 681 times
Re: [NEWS] Introducing MFS
There is a driver for L4 in trunk, see the other topic, you can use it as a template.
What is the expected behavior in function when the device has only one bank?
There is a note in the function;
Should I just return FLASH_NO_ERROR and do nothing?
flash_error_t efl_lld_start_erase_all(void *instance)
This function only erases bank 2 if it is present. Bank 1 is not
touched because it is where the program is running on.\
Pages on bank 1 can be individually erased.
Better return an error, FLASH_NO_ERROR means that an erase is in progress and polling should be started.
Right, will return FLASH_ERROR_HW_FAILURE, as the doc says:
Kind of...
@retval FLASH_ERROR_HW_FAILURE if access to the memory failed.
Kind of...
Here is an initial implementation for F1XX. I'll test it tonight and let you guys know.
Small changes from L4 driver:
I'm unable to upload an attachment, "Invalid file extension: driver_f1.diff".
- Removed unused defines, FLASH_PDKEY1, FLASH_PDKEY2, FLASH_OPTKEY1, FLASH_OPTKEY1
- Removed already defined defines FLASH_KEY1 and FLASH_KEY2, defined on os/common/ext/ST/STM32F1xx/stm32f1xxxx.h
- Use of FLASH_BASE instead 0x08000000U hardcoded
- Created the function stm32_flash_is_busy, to read FLASH_SR_BSY flag
- Removed osalDbgAssert on stm32_flash_check_errors, F1 has no such flags
- efl_lld_start_erase_all does nothing, return FLASH_ERROR_HW_FAILURE, will wait for the unimplemented error
- Changed in efl_lld_query_erase parameter msec to wait_time, as it is defined in the header
diff --git a/os/hal/ports/STM32/STM32F1xx/hal_efl_lld.c b/os/hal/ports/STM32/STM32F1xx/hal_efl_lld.c
new file mode 100644
index 000000000..399777d31
--- /dev/null
+++ b/os/hal/ports/STM32/STM32F1xx/hal_efl_lld.c
@@ -0,0 +1,491 @@
+ ChibiOS - Copyright (C) 2006..2018 Giovanni Di Sirio
+ Licensed under the Apache License, Version 2.0 (the "License");
+ you may not use this file except in compliance with the License.
+ You may obtain a copy of the License at
+ http://www.apache.org/licenses/LICENSE-2.0
+ Unless required by applicable law or agreed to in writing, software
+ distributed under the License is distributed on an "AS IS" BASIS,
+ WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ See the License for the specific language governing permissions and
+ limitations under the License.
+ * @file hal_efl_lld.c
+ * @brief STM32L4xx Embedded Flash subsystem low level driver source.
+ * @addtogroup HAL_EFL
+#include <string.h>
+#include "hal.h"
+#if (HAL_USE_EFL == TRUE) || defined(__DOXYGEN__)
+/* Driver local definitions. */
+#define STM32_FLASH_SECTOR_SIZE 1024U
+#define STM32_FLASH_LINE_SIZE 2U
+#define STM32_FLASH_LINE_MASK (STM32_FLASH_LINE_SIZE - 1U)
+/* Driver exported variables. */
+ * @brief EFL1 driver identifier.
+EFlashDriver EFLD1;
+/* Driver local variables and types. */
+static const flash_descriptor_t efl_lld_descriptor = {
+ .attributes = FLASH_ATTR_ERASED_IS_ONE |
+ FLASH_ATTR_MEMORY_MAPPED,
+ .page_size = STM32_FLASH_LINE_SIZE,
+ .sectors_count = STM32_FLASH_NUMBER_OF_BANKS *
+ STM32_FLASH_SECTORS_PER_BANK,
+ .sectors = NULL,
+ .sectors_size = STM32_FLASH_SECTOR_SIZE,
+ .address = (uint8_t *)FLASH_BASE,
+ .size = STM32_FLASH_NUMBER_OF_BANKS *
+ STM32_FLASH_SECTORS_PER_BANK *
+ STM32_FLASH_SECTOR_SIZE
+/* Driver local functions. */
+static inline void stm32_flash_lock(EFlashDriver *eflp) {
+ eflp->flash->CR |= FLASH_CR_LOCK;
+static inline void stm32_flash_unlock(EFlashDriver *eflp) {
+ eflp->flash->KEYR |= FLASH_KEY1;
+ eflp->flash->KEYR |= FLASH_KEY2;
+static inline void stm32_flash_enable_pgm(EFlashDriver *eflp) {
+ eflp->flash->CR |= FLASH_CR_PG;
+static inline void stm32_flash_disable_pgm(EFlashDriver *eflp) {
+ eflp->flash->CR &= ~FLASH_CR_PG;
+static inline void stm32_flash_clear_status(EFlashDriver *eflp) {
+ eflp->flash->SR = 0x0000001FU;
+static inline uint32_t stm32_flash_is_busy(EFlashDriver *eflp) {
+ return (eflp->flash->SR & FLASH_SR_BSY);
+static inline void stm32_flash_wait_busy(EFlashDriver *eflp) {
+ /* Wait for busy bit clear.*/
+ while (stm32_flash_is_busy(eflp) != 0U) {
+static inline flash_error_t stm32_flash_check_errors(EFlashDriver *eflp) {
+ uint32_t sr = eflp->flash->SR;
+ /* Clearing error conditions.*/
+ eflp->flash->SR = sr & 0x0000001FU;
+ /* Decoding relevant errors.*/
+ if ((sr & FLASH_SR_WRPRTERR) != 0U) {
+ return FLASH_ERROR_HW_FAILURE;
+ if ((sr & FLASH_SR_PGERR) != 0U) {
+ return FLASH_ERROR_PROGRAM; /* There is no error on erase.*/
+ return FLASH_NO_ERROR;
+/* Driver interrupt handlers. */
+/* Driver exported functions. */
+ * @brief Low level Embedded Flash driver initialization.
+ * @notapi
+void efl_lld_init(void) {
+ /* Driver initialization.*/
+ eflObjectInit(&EFLD1);
+ EFLD1.flash = FLASH;
+ * @brief Configures and activates the Embedded Flash peripheral.
+ * @param[in] eflp pointer to a @p EFlashDriver structure
+ * @notapi
+void efl_lld_start(EFlashDriver *eflp) {
+ stm32_flash_unlock(eflp);
+ FLASH->CR = 0x00000000U;
+ * @brief Deactivates the Embedded Flash peripheral.
+ * @notapi
+void efl_lld_stop(EFlashDriver *eflp) {
+ stm32_flash_lock(eflp);
+ * @brief Gets the flash descriptor structure.
+ * @param[in] ip pointer to a @p EFlashDriver instance
+ * @return A flash device descriptor.
+ * @notapi
+const flash_descriptor_t *efl_lld_get_descriptor(void *instance) {
+ (void)instance;
+ return &efl_lld_descriptor;
+ * @brief Read operation.
+ * @param[in] offset flash offset
+ * @param[in] n number of bytes to be read
+ * @param[out] rp pointer to the data buffer
+ * @return An error code.
+ * @retval FLASH_NO_ERROR if there is no erase operation in progress.
+ * @retval FLASH_BUSY_ERASING if there is an erase operation in progress.
+ * @retval FLASH_ERROR_READ if the read operation failed.
+ * @retval FLASH_ERROR_HW_FAILURE if access to the memory failed.
+ * @notapi
+flash_error_t efl_lld_read(void *instance, flash_offset_t offset,
+ size_t n, uint8_t *rp) {
+ EFlashDriver *devp = (EFlashDriver *)instance;
+ flash_error_t err = FLASH_NO_ERROR;
+ osalDbgCheck((instance != NULL) && (rp != NULL) && (n > 0U));
+ osalDbgCheck((size_t)offset + n <= (size_t)efl_lld_descriptor.size);
+ osalDbgAssert((devp->state == FLASH_READY) || (devp->state == FLASH_ERASE),
+ "invalid state");
+ /* No reading while erasing.*/
+ if (devp->state == FLASH_ERASE) {
+ return FLASH_BUSY_ERASING;
+ /* FLASH_READY state while the operation is performed.*/
+ devp->state = FLASH_READ;
+ /* Clearing error status bits.*/
+ stm32_flash_clear_status(devp);
+ /* Actual read implementation.*/
+ memcpy((void *)rp, (const void *)efl_lld_descriptor.address + offset, n);
+ /* Ready state again.*/
+ devp->state = FLASH_READY;
+ return err;
+ * @brief Program operation.
+ * @note It is only possible to write erased pages once except
+ * when writing all zeroes.
+ * @param[in] n number of bytes to be programmed
+ * @param[in] pp pointer to the data buffer
+ * @retval FLASH_ERROR_PROGRAM if the program operation failed.
+ * @notapi
+flash_error_t efl_lld_program(void *instance, flash_offset_t offset,
+ size_t n, const uint8_t *pp) {
+ osalDbgCheck((instance != NULL) && (pp != NULL) && (n > 0U));
+ "invalid state");
+ /* No programming while erasing.*/
+ /* FLASH_PGM state while the operation is performed.*/
+ devp->state = FLASH_PGM;
+ /* Enabling PGM mode in the controller.*/
+ stm32_flash_enable_pgm(devp);
+ /* Actual program implementation.*/
+ while (n > 0U) {
+ volatile uint32_t *address;
+ union {
+ uint16_t hw[STM32_FLASH_LINE_SIZE / sizeof (uint16_t)];
+ uint8_t b[STM32_FLASH_LINE_SIZE / sizeof (uint8_t)];
+ } line;
+ /* Unwritten bytes are initialized to all ones.*/
+ line.hw[0] = 0xFFFFU;
+ /* Programming address aligned to flash lines.*/
+ address = (volatile uint32_t *)(efl_lld_descriptor.address +
+ (offset & ~STM32_FLASH_LINE_MASK));
+ /* Copying data inside the prepared line.*/
+ do {
+ line.b[offset & STM32_FLASH_LINE_MASK] = *pp;
+ offset++;
+ n--;
+ pp++;
+ while ((n > 0U) & ((offset & STM32_FLASH_LINE_MASK) != 0U));
+ /* Programming line.*/
+ address[0] = line.hw[0];
+ stm32_flash_wait_busy(devp);
+ err = stm32_flash_check_errors(devp);
+ if (err != FLASH_NO_ERROR) {
+ break;
+ /* Check for flash error.*/
+ if(address[0] != line.hw[0])
+ err = FLASH_ERROR_PROGRAM;
+ break;
+ /* Disabling PGM mode in the controller.*/
+ stm32_flash_disable_pgm(devp);
+ return err;
+ * @brief Starts a whole-device erase operation.
+ * @note This function does nothing, as STM32F1 has only one bank
+ * and it is where the program is running on.
+ * @notapi
+flash_error_t efl_lld_start_erase_all(void *instance) {
+ (void) instance;
+ * @brief Starts an sector erase operation.
+ * @param[in] sector sector to be erased
+ * @notapi
+flash_error_t efl_lld_start_erase_sector(void *instance,
+ flash_sector_t sector) {
+ osalDbgCheck(instance != NULL);
+ osalDbgCheck(sector < efl_lld_descriptor.sectors_count);
+ "invalid state");
+ /* No erasing while erasing.*/
+ devp->state = FLASH_ERASE;
+ /* Enable page erase.*/
+ devp->flash->CR |= FLASH_CR_PER;
+ /* Set the page.*/
+ devp->flash->AR = sector;
+ /* Start the erase.*/
+ devp->flash->CR |= FLASH_CR_STRT;
+ * @brief Queries the driver for erase operation progress.
+ * @param[out] wait_time recommended time, in milliseconds, that
+ * should be spent before calling this
+ * function again, can be @p NULL
+ * @retval FLASH_ERROR_ERASE if the erase operation failed.
+ * @api
+flash_error_t efl_lld_query_erase(void *instance, uint32_t *wait_time){
+ flash_error_t err;
+ /* If there is an erase in progress then the device must be checked.*/
+ /* Checking for operation in progress.*/
+ if (stm32_flash_is_busy(devp) == 0U) {
+ /* Disabling the various erase control bits.*/
+ devp->flash->CR &= ~(FLASH_CR_OPTER | FLASH_CR_OPTPG |
+ FLASH_CR_MER | FLASH_CR_PER);
+ /* Back to ready state.*/
+ err = FLASH_NO_ERROR;
+ else {
+ /* Recommended time before polling again, this is a simplified
+ implementation.*/
+ if (wait_time != NULL) {
+ *wait_time = (uint32_t)STM32_FLASH_WAIT_TIME_MS;
+ err = FLASH_BUSY_ERASING;
+ else {
+ return err;
+ * @brief Returns the erase state of a sector.
+ * @param[in] sector sector to be verified
+ * @retval FLASH_NO_ERROR if the sector is erased.
+ * @retval FLASH_ERROR_VERIFY if the verify operation failed.
+ * @notapi
+flash_error_t efl_lld_verify_erase(void *instance, flash_sector_t sector) {
+ uint32_t *address;
+ unsigned i;
+ "invalid state");
+ /* No verifying while erasing.*/
+ /* Address of the sector.*/
+ address = (uint32_t *)(efl_lld_descriptor.address +
+ flashGetSectorOffset(getBaseFlash(devp), sector));
+ /* Scanning the sector space.*/
+ for (i = 0U; i < STM32_FLASH_SECTOR_SIZE / sizeof(uint32_t); i++) {
+ if (*address != 0xFFFFFFFFU) {
+ err = FLASH_ERROR_VERIFY;
+ break;
+ address++;
+ return err;
+#endif /* HAL_USE_EFL == TRUE */
diff --git a/os/hal/ports/STM32/STM32F1xx/hal_efl_lld.h b/os/hal/ports/STM32/STM32F1xx/hal_efl_lld.h
index 000000000..c2dfb1bac
--- /dev/null
+++ b/os/hal/ports/STM32/STM32F1xx/hal_efl_lld.h
@@ -0,0 +1,116 @@
+ * @file hal_efl_lld.h
+ * @brief STM32F1xx Embedded Flash subsystem low level driver header.
+#ifndef HAL_EFL_LLD_H
+#define HAL_EFL_LLD_H
+/* Driver constants. */
+/* Driver pre-compile time settings. */
+ * @name STM32F1xx configuration options
+ * @brief Suggested wait time during erase operations polling.
+#if !defined(STM32_FLASH_WAIT_TIME_MS) || defined(__DOXYGEN__)
+#define STM32_FLASH_WAIT_TIME_MS 1
+#endif
+/* Derived constants and error checks. */
+#if !defined(STM32_FLASH_NUMBER_OF_BANKS)
+#error "STM32_FLASH_NUMBER_OF_BANKS not defined in registry"
+#endif
+#if !defined(STM32_FLASH_SECTORS_PER_BANK)
+#error "STM32_FLASH_SECTORS_PER_BANK not defined in registry"
+#endif
+/* Driver data structures and types. */
+/* Driver macros. */
+ * @brief Low level fields of the embedded flash driver structure.
+#define efl_lld_driver_fields \
+ /* Flash registers.*/ \
+ FLASH_TypeDef *flash
+ * @brief Low level fields of the embedded flash configuration structure.
+#define efl_lld_config_fields \
+ /* Dummy configuration, it is not needed.*/ \
+ uint32_t dummy
+/* External declarations. */
+#if !defined(__DOXYGEN__)
+extern EFlashDriver EFLD1;
+#endif
+#ifdef __cplusplus
+extern "C" {
+#endif
+ void efl_lld_init(void);
+ void efl_lld_start(EFlashDriver *eflp);
+ void efl_lld_stop(EFlashDriver *eflp);
+ const flash_descriptor_t *efl_lld_get_descriptor(void *instance);
+ flash_error_t efl_lld_read(void *instance, flash_offset_t offset,
+ size_t n, uint8_t *rp);
+ flash_error_t efl_lld_program(void *instance, flash_offset_t offset,
+ size_t n, const uint8_t *pp);
+ flash_error_t efl_lld_start_erase_all(void *instance);
+ flash_error_t efl_lld_start_erase_sector(void *instance,
+ flash_sector_t sector);
+ flash_error_t efl_lld_query_erase(void *instance, uint32_t *wait_time);
+ flash_error_t efl_lld_verify_erase(void *instance, flash_sector_t sector);
+#ifdef __cplusplus
+#endif
+#endif /* HAL_EFL_LLD_H */
diff --git a/os/hal/ports/STM32/STM32F1xx/platform.mk b/os/hal/ports/STM32/STM32F1xx/platform.mk
index 4179fa910..8ff4f5331 100644
--- a/os/hal/ports/STM32/STM32F1xx/platform.mk
+++ b/os/hal/ports/STM32/STM32F1xx/platform.mk
@@ -1,7 +1,8 @@
# Required platform files.
PLATFORMSRC := $(CHIBIOS)/os/hal/ports/common/ARMCMx/nvic.c \
$(CHIBIOS)/os/hal/ports/STM32/STM32F1xx/stm32_isr.c \
- $(CHIBIOS)/os/hal/ports/STM32/STM32F1xx/hal_lld.c
+ $(CHIBIOS)/os/hal/ports/STM32/STM32F1xx/hal_lld.c \
+ $(CHIBIOS)/os/hal/ports/STM32/STM32F1xx/hal_efl_lld.c
# Required include directories.
PLATFORMINC := $(CHIBIOS)/os/hal/ports/common/ARMCMx \
diff --git a/os/hal/ports/STM32/STM32F1xx/stm32_registry.h b/os/hal/ports/STM32/STM32F1xx/stm32_registry.h
index dc9dd13e7..f643b9bad 100644
--- a/os/hal/ports/STM32/STM32F1xx/stm32_registry.h
+++ b/os/hal/ports/STM32/STM32F1xx/stm32_registry.h
@@ -115,6 +115,12 @@
#define STM32_EXTI_NUM_LINES 19
#define STM32_EXTI_IMR_MASK 0x00000000U
+/* Flash attributes.*/
+#define STM32_FLASH_NUMBER_OF_BANKS 1
+#if !defined(STM32_FLASH_SECTORS_PER_BANK) || defined(__DOXYGEN__)
+#define STM32_FLASH_SECTORS_PER_BANK 32 /* Maximum, can be redefined.*/
+#endif
/* GPIO attributes.*/
#define STM32_HAS_GPIOA TRUE
#define STM32_HAS_GPIOB TRUE
@@ -321,6 +327,12 @@
+#endif
@@ -499,6 +511,12 @@
+#define STM32_FLASH_SECTORS_PER_BANK 128 /* Maximum, can be redefined.*/
+#endif
@@ -710,6 +728,12 @@
+#define STM32_FLASH_SECTORS_PER_BANK 256 /* Maximum, can be redefined.*/
+#endif
@@ -943,6 +967,12 @@
+#define STM32_FLASH_NUMBER_OF_BANKS 2
+#endif
@@ -1196,6 +1226,12 @@
#define STM32_EXTI_NUM_LINES 20
+#endif
It looks very similar except for the program lines of just 2 bytes. You may also post the files zipped, the forum only accepts .zip and .7z.
