http://chibios.sourceforge.net/html/str ... annel.html page points to http://chibios.sourceforge.net/html/str ... tream.html which seems to be 404?
Something must be wrong - should http://chibios.sourceforge.net/html/str ... annel.html be removed or http://chibios.sourceforge.net/html/str ... tream.html added or else?
Doxygen struct_base_sequential_stream.html Page Not Found Topic is solved
- wurstnase
- Has thanked: 43 times
- Been thanked: 30 times
Re: Doxygen struct_base_sequential_stream.html Page Not Found
Probably you want some more actual documents.
http://www.chibios.org/dokuwiki/doku.ph ... tion:start
The one you get from Google(?) is somehow outdated.
\o/ Nico
Please look at the documentation page for more up to date links. Files have been removed from SF because all the issues they had after migration.
http://chibios.org/dokuwiki/doku.php?id ... tion:start
- russian
- Has thanked: 16 times
- Been thanked: 14 times
Giovanni wrote:Please look at the documentation page for more up to date links. Files have been removed from SF because all the issues they had after migration.
These links are the first hits with google search. Are these files under your control? Are you not removing them completely due to lack of time for the cleanup or what is the reason to keep these outdated files in place?
With google using these as first results would it be more user-friendly to change it with some warning or a redirect or else?
I do not have a problem finding current documentation, I am trying to propose an improvement which could help others by reducing the clutter.
http://rusefi.com/ - electronic fuel injection
- russian
wurstnase wrote:Probably you want some more actual documents.
Nope, I am looking to solve the problem. The problem is that google is currently pointing at outdated documentation. Unless there is a way to point google to the current location I believe the outdated location could be somehow cleaned-up to reduce confusion. Just a bunch of static redirect pages could help.
I am available to help if there is way to help. Would it be needed to generate a set of files with names matching the file names of old doxygen folder but with redirect content? I can generate that set of files if that would help.
I think at some points old pages will be removed by google, theit crawler will see that there is nothing any more there.
- russian
But pages are still there? Can you remove more pages like the first link from top post?
Under /html/ there is nothing, pages are under /docs/ and /docs3/.
- russian
I do not follow
http://chibios.sourceforge.net/html/struct_base_channel.html is not a google cached page, that's a real alive page at chibios.sourceforge.net web server, isn't it?
Or is it that sourceforge.net does not allow you to remove or replace this page?
No, it is just that I was looking in the wrong place, I am erasing it now....
