I'm new of Chibios/RT, sorry for my dummy question. What's the equivalent of xQueueCreate of FreeRTOS?
I know that in ChRt we have mailboxes, I/O queues, sync messages but it's not clear for me what the best choise to replace the xQueueCreate class. My need is to have queues of structs to share data between tasks/tasks and ISR/tasks.
Thanks, regards
xQueueCreate equivalent
- Has thanked: 787 times
- Been thanked: 681 times
Re: xQueueCreate equivalent
Look at "Object Queues", it is a pool of structures of the same size exchanged via a mailbox: Get a structure from the pool, send it, receive it, return it to the pool.
It can be used by ISR and tasks, fully static.
Giovanni wrote:Hi,
Thanks for your reply. I'm not able to find info about object queues, sorry, could you give me more details/links?
Thanks
You can also use (abuse?) I/O Buffers Queues.
http://chibios.sourceforge.net/docs/19. ... e_r_s.html
It may even be faster than Object FIFOs. Any comments on the fastest block based queue implementation in ChibiOS Giovanni?
Those are different, ObjFIFOs are meant to exchange fixed-size structures in a copy-less way.
HAL I/O buffers are used in those situations where you have to read/write byte streams from one side and fetch/post buffers from the other side, it is more of a buffering system.
Which is better depends on the use case.
Giovanni wrote:Those are different, ObjFIFOs are meant to exchange fixed-size structures in a copy-less way.
From the API documentation:
Buffers Queues are used when there is the need to exchange fixed-length data buffers between ISRs and threads.
It has a byte queue emulation API as well, but can certain be used for fixed length object.
Need to benchmark...
For a byte queue, what's the difference between an I/O queue, and the new pipe_t ?
I/O queues are asymmetric, there always is an ISR (low) side and a thread (high) side, in addition, there is a callback notification mechanism high->low. It is specialized for a specific use, serial-like drivers. This is why I/O queues are in HAL, same for buffer queues.
Pipes are generic thread to thread byte streams with no specific use.
- Has thanked: 11 times
- Been thanked: 4 times
Are HAL I/O BUFFERS not copy-less too?
AQ
