chThdSleepX stucks while debugging on STM32F030x4 Topic is solved
- Has thanked: 807 times
- Been thanked: 705 times
Re: chThdSleepX stucks while debugging on STM32F030x4
The last safe GCC version for Cortex-M0 is 5.4.1. This problem does not affect other Cortex cores.
I will add it to 18.2.x too.
For those who face with this problem in the future:
1. Compiling the gcc-arm-none-eabi-5.4.1 from source seems very complicated and currently I've no success: https://unix.stackexchange.com/q/511072/65781
2. Downloading the precompiled toolchain from https://launchpad.net/gcc-arm-embedded/ ... -q3-update and setting the $PATH variable accordingly doesn't work either. Context switch still doesn't work.
3. The best bet (currently working solution) is finding an old Linux installation and using this under a virtual machine.
The compiler is available from here: https://developer.arm.com/tools-and-sof ... /downloads
It is also included in ChibiStudio.
No need to build anything.
I downloaded https://developer.arm.com/-/media/Files ... -q1-update which is the same binary as I downloaded from Launchpad and is not working correctly.
I prefer not to use ChibiStudio since I've created a workflow based on using ChibiOS in command line, so using ChibiStudio is not an option in my case.
Isn't it sufficient to prepend the "/path/to/extracted-toolchain-location/bin" path in front of the PATH environment variable? In my case correct compiler path is resolved:
however context switch still doesn't work. Should I need to make another preparation other then modifying PATH variable?
(gdb) shell arm-none-eabi-gcc -dumpversion
5.3.1
No other preparation, just make sure you are invoking the right compiler if you have multiple instances. It should just work.
Seems to be resolved in new GCC release.
From 6c916b07ff6010d1d7c597927be546682ac598bb Mon Sep 17 00:00:00 2001
Date: Fri, 24 Apr 2020 03:34:41 +0300
Subject: [PATCH] updated GCC bug warning related to Cortex-M0 regarding to the
fix
os/common/ports/ARMCMx/chcore_v6m.h | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/os/common/ports/ARMCMx/chcore_v6m.h b/os/common/ports/ARMCMx/chcore_v6m.h
index e43f5030cf..78e76c7576 100644
--- a/os/common/ports/ARMCMx/chcore_v6m.h
+++ b/os/common/ports/ARMCMx/chcore_v6m.h
@@ -128,9 +128,9 @@
/* Handling a GCC problem impacting ARMv6-M.*/
#if defined(__GNUC__) && !defined(PORT_IGNORE_GCC_VERSION_CHECK)
-#if __GNUC__ > 5
+#if __GNUC__ > 5 && __GNUC__ < 8
#warning "This compiler has a know problem with Cortex-M0, see bugs: 88167, 88656."
-#warning "*** Use GCC version 5 or below ***"
+#warning "*** Use GCC version (5 or below) or (8 or above) ***"
Careful, GCC version 9-2019-q4 is still affected by the problem.
Giovanni wrote:Hi,
Oh, there was an already opened thread for that: viewtopic.php?t=5449&p=37460
Is this a new bug or those fixes didn't fix the problem correctly? Currently my test application performs the context switch correctly. Is it still the same context switch problem?
It is the same problem, context switch thread-to-thread works but it does not reschedule after an interrupt.
