Solving one issue with latest Studio, GCC7 or 9 and Chibios 2.0.3
I can compile and run program without issues, I can breakpoint. Chibios debug view doesn't
but all thread code like
static THD_WORKING_AREA(AdcThreadWorkingArea, 128);
or
static THD_FUNCTION(AdcThread, arg) { }
have mark as Syntax error in IDE. It compiles but show this and thus I am unable to inspect properties with mouse over. On other places it works.
Anyone have idea what is wrong ? In Problems is listed
Description Resource Path Location Type
Program "g++" not found in PATH BB8v2 Project Properties, C++ Preprocessor Include.../Providers, [CDT Cross GCC Built-in Compiler Settings] options C/C++ Scanner Discovery Problem
Program "g++" not found in PATH BB8v2 [Discovery Options] page in project properties C/C++ Problem
but it was there in old studio too and didn't made that problems.
Using C++ for build
New Studio - Syntax error in IDE on working code
- Has thanked: 1077 times
Re: New Studio - Syntax error in IDE on working code
It is possible that g++.exe is missing, in the compiler also gcc.exe is missing but we add it manually, probably we need to add g++.exe too.
Locate where gcc.exe is under /tools and in the same location add g++.exe obtained by renaming arm-none-eabi-g++.exe.
We may have missed it because g++ is also in some other place in system path on our PCs.
- RoccoMarco
- Has thanked: 83 times
- Been thanked: 67 times
I am trying to reproduce your issue with no luck on my side. I have a clean version of ChibiStudio 2020-04 and no extra stuff in the path.
Could you try to build the project index to see if the issue disappears? Could you share a screenshot fo your ChibiStudio?
Ciao,
RM
RM
copy g++ fixed one error (but second stays). I tried to expand Index resettings, tried couple of others settings in IDE and not help.
I moved my working code out to simple function so I am 100% sure that it is not made by code inside of thread macro.
GCC is 9
GCC is 9
HI,
Have you tried to re-index the project?
Right click on project -> Index -> Rebuild.
Strange, it is something specific in your project setup I think, does that happen also with the demo applications in ChibiStudio?
Not really used the latest IDE yet, but on earlier ones the problem has sometimes been that the IDE syntax checker doesn't know the path of the macro definition.
I've seen it mostly when including compiler libraries.
I have a vague recollection of a maximum file nesting depth which meant that some definitions were missed.
Maybe a link to the Chibi sources within the project will fix it?
ok, so I used fresh Chibistudio and imported project into User workspace and problem is fixed.
Maybe something with update or messed by me.
Thanks for help
Thanks for help
