pannel config help
mobyfab
Has thanked: 21 times
Been thanked: 30 times
Re: pannel config help
Postby mobyfab » Thu May 02, 2013 3:49 pm
daviddawe1982 wrote:the post int board was it the lcd now displays i added some text from text example but it displays backwards..
The display is horizontally inverted?
If so please add this in the post init function:
write_index(SSD1963_SET_ADDRESS_MODE);
write_data(2);
This should flip the screen horizontally.
daviddawe1982
Postby daviddawe1982 » Thu May 02, 2013 4:15 pm
THANK YOU!!
It worked like a charm.
Mobyfab i cannot thank you enough.. :D :D :D
Postby Tectu » Thu May 02, 2013 4:27 pm
Good to see that you finally got your display working, david. Now, enjoy the goodies and badies of ChibiOS/GFX :P
mobyfab
Postby mobyfab » Thu May 02, 2013 4:30 pm
You're welcome :)
You should try to play with the FSMC clock dividers that you commented in the post init function earlier.
Just so that you can get the best performance possible with your hardware.
Users browsing this forum: No registered users and 35 guests
