I have done some benchmarks with SSD1289 using GPIO and FSMC.
I have used this souce code https://github.com/etmatrix/ChibiOS-GFX ... nch/main.c posted by mobyfab.
I got about 2400000 with GPIO and about 5300000 with FSMC. Without using CS in acquire and release bus I got about 2800000 with GPIO.
Has anyone ever tried it?
Benchmark SSD1289
Re: Benchmark SSD1289
Hello etmatrix,
Thanks for your data. I never really found time myself for making benchmarks.
Would you be open to create a main.c + gfxconf.h for demos/benchmarks in the repository? The demo could run several thins like normal pixel manipulation as well as area blitting and others and display the values like pixels/sec. on the screen afterwards. What do you say?
Of course you don't need the CS thing as long as you don't have anything else connected to your bus. This is the advantage of the board files. You can simply optimize everything for your hardware setup!
Kind regards,
Kind regards,
Hello Tectu,
I have done for test FSMC and understand the advantages to use it.Tectu wrote:I never really found time myself for making benchmarks.
Ok done! The first version do a simple gdispFillArea, as original version. I need to understand better CPU_RESET_CYCLECOUNTER, I think that code works only on STM32F4xx.Tectu wrote:Would you be open to create a main.c + gfxconf.h for demos/benchmarks in the repository? The demo could run several thins like normal pixel manipulation as well as area blitting and others and display the values like pixels/sec. on the screen afterwards. What do you say?
Thank you very much for your pull request, It's already in the repo master.
Please note that You have to take the proper file header. You took the ChibiOS/RT license header. I replaced the header by the proper one you can find in any ChibiOS/GFX file.
Also, I made a few more cleanups (removed the noreturn attribute for since not every compiler might support that as well as the gdispInit() has been moved into the main where it belongs.
However, I couldn't try the demo out yet. I'll do that somewhen this night.
File free to update the demo whenever you want
~ Tecut
~ Tecut
Okay. I tried the benchmark out and I also made a little cleanup.
Here are my results:
- STM32F103RBT, 240x320, GPIO: 3640048 Pixels/s
My error, I'm a newbie on ARM. That code should be works with all Cortex-M3 and over.etmatrix wrote:I need to understand better CPU_RESET_CYCLECOUNTER, I think that code works only on STM32F4xx.
My connections with GPIO use bit-banging. I forget to write this information.
Sorry, I cannot help you with that macro, but feel free to tell me the answer when you find out
Eddie
- Has thanked: 2 times
- Been thanked: 6 times
Hello, I improved SSD1289 driver performance using FSMC and DMA on STM32F4. Also added backlight control using PWM output.
Tested on STM32F4 Discovery and TFT LCD HY32C.
Benchmark:
FSMC DMA off - 6 Mpix/sec
FSMC DMA on - 17 Mpix/sec
Eddie
Benchmark:
Eddie
- ADS7843.ZIP
- (6.63 KiB) Downloaded 910 times
- SSD1289.ZIP
- (12.21 KiB) Downloaded 1036 times
mobyfab
- Has thanked: 21 times
- Been thanked: 31 times
You can use halGetCounterValue() and just skip reseting the cpu cycles counter.
Also try to play with the FSMC delays to get the best performance possible
As far as I know the SSD1289 was already using FSMC and DMA ported from my SSD1963 code.
Edit: seems like the FSMC board file has the DMA config, but the fillarea/blitarea functions do not handle DMA requests.
uint32_t start = halGetCounterValue();
for (i = 0; i < 5000; i++) {
uint32_t ms = (halGetCounterValue()-start) / 168000;
Thank you very much for your contribution Eddie. I took a look to your changes and everything looks nice. It also works without any issues here. Therefore I have commited the changes and added your contribution to credits table.
Awaiting your next contribution
