AVR Nil demo takes up almost 6k? Topic is solved
rongcuid
Postby rongcuid » Fri Jan 13, 2017 7:39 pm
According to the documents, ChibiOS/Nil should not exceed 1KB at maximum configuration. However, when I try to compile the NIL-ARDUINOUNO demo:
Size after:
AVR Memory Usage
Device: atmega328p
Program:    5278 bytes (16.1% Full)
(.text + .data + .bootloader)
Data:        555 bytes (27.1% Full)
(.data + .bss + .noinit)
-------- end --------
This doesn't look quite right, as the bare example alone takes up almost 6k. I tried changing compiler optimization, and it doesn't help a lot here. The make output indicates that the demo is correctly linked to NIL files, so it is not incorrectly linked to RT or something.
Or am I misunderstanding the claim about space? Does HAL take a large chunk of space too?
rongcuid
Re: AVR Nil demo takes up almost 6k?
Postby rongcuid » Fri Jan 13, 2017 7:59 pm
OK, after some investigation, it looks like that those 5K are actually taken by HAL. Enabling everything in Nil config simply adds a few hundred B to the final size, so I guess that is it.
Postby Giovanni » Fri Jan 13, 2017 8:51 pm
Correct, NIL alone, the RTOS, is very small but HAL size varies depending the enabled drivers.
Return to “ChibiOS/NIL”
