I have downloaded the latest ChibiStudio. Opened the STM32F429 demo project.
Compilation worked without errors. After setting up a debug configuration, connecting the board, debugger start reports: "Cannot run program "gdb": Launching failed".
Manually searching for "gdb.exe" was not sucessful.
What is wrong? do I have to install the gdb.exe separate?
Regards F. Seuhs
Do I need to install gdb separatly for ChibiStudio?
- Has thanked: 1076 times
- Been thanked: 922 times
- Contact:
Re: Do I need to install gdb separatly for ChibiStudio?
The project should have already a debug configuration In ChibiStudio (see the ./debug directory inside the project, it is the .launch file).
If you need to create your own configuration then make sure to specify arm-none-eabi-gdb as debugger in the "debugger" tab. The GDB executable is present with that name.
Hello Giovanni,
thank you for your answer, the debugger starts now!
I don't really know what I made wrong the first time I tried, and made my own debug configuration.
Maybe starting ChibiStudio again with the opened project, the project launch was found.
But the next problem after loading:
symbol-file C:\\ChibiStudio\\chibios3\\demos\\STM32\\RT-STM32F429-DISCOVERY\\build\\ch.elf
Open On-Chip Debugger 0.9.0-dev-00268-ga9c90a0 (2015-02-08-10:38)
Licensed under GNU GPL v2
For bug reports, read
monitor reset run
"monitor" command not supported by this target.
monitor delay 1000
monitor halt
set remotetimeout 20
monitor reset init
monitor sleep 50
What is the "monitor"? The USB-semihosting?
Thanks for your answer.
monitor reset run
monitor delay 1000
monitor halt
monitor reset init
monitor sleep 50
- Contact:
"monitor" are commands sent directly to the GDB server, OpenOCD in this case, very strange because everything is supposed to work out of the box.
Are you launching ChibiStudio using the provided link or you launch directly Eclipse? you need to use the link because some PATHs are enforced before launching Eclipse.
Users browsing this forum: No registered users and 34 guests
