ChibiOS Debug View help please
Has thanked: 876 times
Been thanked: 750 times
Re: ChibiOS Debug View help please
Postby Giovanni » Tue Sep 06, 2016 8:06 pm
It should work if you are able to debug.
omcdr
Has thanked: 7 times
Postby omcdr » Wed Sep 07, 2016 10:48 am
I have tested in original workspace161
1. STlink works corectly
2. STlink reflashed do J-link - not works - "Error: ChibioOS/RT not found on target"
3. J-link v9 - not works - "Error: ChibioOS/RT not found on target"
It looks there is problem with settings for J-link or JLinkGDBServerCL.exe
Postby Giovanni » Wed Sep 07, 2016 11:14 am
It definitely looks like a probe-related problem, it is strange however, the Eclipse plugin only sees and uses the Eclipse debugger API not the HW directly. I also use an FT2232-based one and it works as well.
ChibiOS is recognized by looking for the "ch" structure in the elf file symbols, is it possible your GDB server has issues with symbols as generated by the compiler?
Return to “ChibiStudio”
